DPM issue
Old   March 27, 2009, 05:46
Unhappy DPM issue
cinmar is on a distinguished road
Hi Guys,
I have the following problem. I should perform a DPM (uncoupled). My flow solution is unsteady. The flow time step is very small and the mesh size is very big (9 million).
What kind of particle tracking should I use for my particles?
I know that the most correct one is the unsteady one but the particle residence time is around 10-2 that for me means to run kind of 100000 iterations....computationally too much expensive (I should wait months). If I run a steady one I can use only the solution at that timestep. Can I use the mean flow field instead?
Thanks for you help,
Cinzia
cinmar is offline   Reply With Quote
DPM and LES R.Sripriya FLUENT 6 April 15, 2017 04:41
DPM with UDF - Step-by-Step Procedure???? Prashanth FLUENT 3 April 3, 2009 17:45
DPM - do the particles affect the liquid? Nikhil Dani FLUENT 0 January 1, 2009 11:58
problem about DPM of cyclone separator simulation jason FLUENT 4 November 12, 2007 03:15
slow after mesh for enhanced wall treat DPM joshkemp FLUENT 0 May 1, 2007 17:20
