using rate equation for volumetric reaction
Old   March 31, 2009, 13:09
Default using rate equation for volumetric reaction
Byron Smith R J
byronsmith is on a distinguished road
hai
I am trying a reaction in fluent for which i have its rate equation. i have written a udf and the udf is compiling and is hooked in fluent. but when i open the reactions panel for finite rate it asks the preexponential and activation energy. can someone help me by giving the procedure of using the rate equation to run the reaction in fluent.
byronsmith is offline   Reply With Quote
Old   April 1, 2009, 03:16
Sathees Kannan
satheeskannan is on a distinguished road
Send a message via Skype™ to satheeskannan
you have to give pre-exponential factor and activation energy in Fluent Reaction panel. Fluent will pass these values to your UDF.
satheeskannan is offline   Reply With Quote
Old   April 1, 2009, 03:46
anonym
Laci is on a distinguished road
Originally Posted by byronsmith View Post
hai
The reaction rate constant (k) is calculated from this two value with the Arrhenius equation. This is how the 'k' become temperature dependent.
Laci is offline   Reply With Quote
Old   April 8, 2009, 11:58
Byron Smith R J
hai
thanks for ur reply. but I have a reaction rate equation where the k value and keq value are expressed in terms of temperature. so the udf will take the temperature from the fluent and calculates the rate of the reaction. I want to use this reaction rate instead of the rate expressed by arrhenius type in the reactions panel. how to do that
Old   April 14, 2019, 12:28
郝晨睿
kimi_hao is on a distinguished road
Hi, i am doing a similar work and having the same problem. Have you settled that?
kimi_hao is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
surface reaction rate zhou FLUENT 4 October 2, 2003 16:16
Chemical reaction rate in enthalpy equation Jianping Zhang Main CFD Forum 1 July 16, 2003 10:10
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
User Defined Reaction Rate John McKelliget FLUENT 1 December 17, 1999 10:44
