Wind Turbine + MRF (Multiple Reference Frame)
Old   April 21, 2009, 05:59
Default Wind Turbine + MRF (Multiple Reference Frame)
Ebi
abolfazl is on a distinguished road
hi to all
I have a problem to implement the MRF, exaclty to bulid two volumes in Gambit.
i dont know the size of the volume(which is rotateded in MRF) around the wind turbine blade?
furthermore, in a computational domain, where is the volume ( moving reference frame zone) must be placed?is it near to the blade or far from the blade? How far?
Thanks for replay.
abolfazl is offline   Reply With Quote
Old   April 22, 2010, 22:46
yashwant
saini.yashwant is on a distinguished road
sir i am student of M.tech at NIT surat. i am doing numerical simulation of wind turbine by fluent. so i am facing some problems with defining the boundary conditions. so wl u please help me regarding boundary conditions.sir i have modeled wind turbine in gambit and meshed it with two domain interior domain with .5d same as wind radius. and another one is off bigger domain of 4d in diameter. and 3d in front and 5d in back. i have defined the interface in between the surfaces of interior and outer domain. by giving the condition of rotor stationary and the near by domain air is rotating i am getting the axial velocity at the rotor plane more than inlet velocity. is this correct or not. and please help me out how to calculate the power output and coefficient of power.
thanks
saini.yashwant is offline   Reply With Quote
Old   February 15, 2012, 15:24
mohamed khedr emam
m5edr is on a distinguished road
Iam face the same problem
I dont know..
Is the blade is fixed and the blade domain is MRF with r.pm speed o he rotor?
Is the whole domain Is fixed or MRF?
I'm really need help, for any one solve the problem
m5edr is offline   Reply With Quote
Old   February 29, 2012, 02:42
APPLE
apple2012 is on a distinguished road
blades and the air near blades are MRF
apple2012 is offline   Reply With Quote
Old   June 2, 2012, 11:15
monaya flower
monaya flower is on a distinguished road
i have the same proplem
did you solve your proplem and how did you calculate the power output?
monaya flower is offline   Reply With Quote
Old   June 2, 2012, 14:45
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
hi
I think you should have a distance of 10 times larger than your turbine diameter, and your boundary condition must be correct. what model of viscosity do you want to use? ideal gas or boussinesq??
adambarfi is offline   Reply With Quote
Old   June 4, 2012, 04:43
monaya flower
hi
I used
1- pressure based solver , relative velocity formulation, steady
2-k-epsilon model , standard
3-for bc i used inlet velocity with 10 m/s , intensity (10)and viscosity ratio (.1) ..... is it right ?
4-i make the wall of the blade rotational , relative to adjacent cell zone , with zero speed
5- i used MRF
6-air with contant density
6- i want to ask how if this bc is right and how can i calculate the output power and torque
Old   May 20, 2013, 18:45
s.q
s.q is on a distinguished road
Originally Posted by monaya flower View Post
hi
I used
5- i used MRF
hi dear monaya
i,m simulating a wind turbine using fluent and i,m using the same bc such as you.but my solution dont converge.and all velocity magnitude contours are 0.
what do you think i should do??
s.q is offline   Reply With Quote
Old   May 28, 2013, 07:44
niloogh is on a distinguished road
hi
I used
5- i used MRF
hi dear monaya
i have the same problem as you;wind turbine and output power
i don't know how to calculate the output power
would you plz tell me how did you figure out your
niloogh is offline   Reply With Quote
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
Building OpenFoAm on SGI Altix 64bits anne OpenFOAM Installation 8 June 15, 2006 09:27
Windows Installation BugsComments on Petrbs patch brooksmoses OpenFOAM Installation 48 April 16, 2006 00:20
