wierd problem with surface reation in Fluent
Old   May 28, 2009, 18:23
Default wierd problem with surface reation in Fluent
Dongzi Wei
Jiuan is on a distinguished road
I am running a case including a gas phase reation and surface reaciton, which are:
SiH4(g) -> SiH2(g)+H2(g) and SiH2(g) ->Si(s)+H2(g). The geometry and boundary condition are rather simple. I input there parameters related to chemical kinetics into Fluent, which are Pre-exponential factor (A), activation energy (Ea), and temperature exponent (Beta). When I change the A or Ea for surface reaciton, the deposition rate of Si does not change, which is very strange. I run more cases to test it, and found out that even if I reduce the value of A by 1000 times, and keep Ea fixed, the deposition rate of Si is the same. I am totally confused by Fluent. . Does anybody have the problem before? Or if you guys have interest, you can have a try. Thanks in advance.
Jiuan
Jiuan is offline   Reply With Quote
Problem in Tutorial problem of fluent Phanindra FLUENT 5 April 17, 2007 09:57
CFX Free Surface problem sam CFX 6 March 21, 2007 18:49
Free surface problem Luk CFX 2 July 27, 2006 01:07
Can -FLUENT solve non-coal particle surface reacti Ganesh kumar FLUENT 0 February 20, 2006 02:03
Problem with ambit Lio FLUENT 4 July 6, 2004 08:23
