How to calculate pressure forces using custom field functions? |
June 22, 2009, 07:57 |
Toni Pujol
Dear all,
I am trying to obtain forces and torques on the blades of an axial fan using a transient simulation. I can obtain them by using the Report => Forces panel. However, I would like to obtain them as a function of time. Therefore, I want to create a Custom Field Function and then make a Monitor => Surface of that Custom Field Function. In order to be confident with what I am doing, I am currently checking if the Custom Field Function I have written gives the same answer as the Report => Forces panel... and I am making one (or several) mistake(s) I am unable to detect. For the x component of the pressure force on the surface, I define a Custom Field Function as: p * x-surface- area and Sum over the surface on the Report => Surface Integrals. The result is very different from that I obtain using the Report => Force panel (it also disagrees with y and z components). Any help? Thanks, Toni |
custom field function, pressure forc |
Variable Operating Pressure (field) | Arturo | FLUENT | 0 | April 30, 2008 15:22 |
Execute Command with Custom Field Functions | Prasad Dudhgaonkar | FLUENT | 0 | March 8, 2007 15:27 |
2d foil pressure forces problem | mayor | FLUENT | 4 | December 1, 2003 03:57 |
Using SIMPLE | david | Main CFD Forum | 5 | July 21, 1999 02:38 |
