Problem with bin_particles_in_cells command
Old   July 14, 2009, 16:14
Default Problem with bin_particles_in_cells command
Mayank Kumar
kmayank is on a distinguished road
I see that the command "bin_particles_in_cells(domain)" is giving me error in Fluent 12 version, saying "Too few arguments". Looks like it needs one more argument, and of int type. The command used to work fine in Fluent 6 with just the 'domain' argument.
If anyone has any idea of the updated usage, I would be grateful.
Thanks
Mayank
kmayank is offline   Reply With Quote
Old   May 13, 2010, 16:05
Default experiencing the same problem
Drew
mcdhrim is on a distinguished road
I have been using User Defined Function: bin_particles_in_cells(d).
This function worked with Fluent 6.3.26 but it does not work anymore with ANSYS FLUENT.
Does anyone know how to go around this problem?
Thanks,
DR
mcdhrim is offline   Reply With Quote
Old   January 18, 2011, 01:33
Roman Gobitz-Pfeifer
Wikie is on a distinguished road
did anybody solve this problem?? I also want to use the command "bin_particles_in_cells(domain)". I'm using version 12.1. The error message is "Too few arguments".
Can anybody help me please I stuck here!!
Thanks,
Wikie
Wikie is offline   Reply With Quote
Old   January 23, 2011, 10:37
I found the function bin_particles_in_cells in the cl_dpm.h file.
"FLUENT_EXPORT void bin_particles_in_cells(Domain *domain, cxboolean init_cells);"
So this function needs another argument init_cells of cxboolean type. Right now I dont't know how to handle this. Does anybody else what is meant by init_cells??
Cheers,
Wikie
Old   November 11, 2011, 03:48
massoud
massoudepsilon is on a distinguished road
Hi every body,
I am using a UDF containing bin_particles_in_cell and I need to know that what this macro does.
I will be grateful if someone can answer it.
Cheers
massoudepsilon is offline   Reply With Quote
Old   May 2, 2012, 03:33
Chao Li
LICH is on a distinguished road
Hi Wikie,
Do you have any idea about the argument "cxboolean init_cells"? I've tried some value(0,1,FALSE,TRUE) for the argument. There is no error and the case can run. BUT the results are obviously wrong. There is NO particle is tracked in the domain.
Thanks a lot.
LICH is offline   Reply With Quote
Old   April 10, 2015, 13:43
B_Kia
HyperNova is on a distinguished road
hi
does anybody here solved the problem about : cxboolean init_cells?
i am using Fluent v 15.0
HyperNova is offline   Reply With Quote
Old   June 8, 2015, 23:46
Luleå tekniska universitet
mac_09 is on a distinguished road
Hello guys,
I have just solved this issue.
Cxboolean type is just T/F data type and init_cells is something I suppose we have to do like, initialize particles in cells.
So try your cases with:
So you can just try
Bin_particles_in_cells(domain, TRUE)
Thanks and good luck.
Regards:
MAC
mac_09 is offline   Reply With Quote
Old   August 28, 2017, 03:41
Default Simple UDF for looping on all particles in each cell.
massoud
Since Fluent 12, the implementation of bin_particles_in_cells(domain, count) has changed and you need additional macro (unthread_particles_to_all_inj(domain, check)). Please be aware that this additional macro had only one argument at least until Fluent version 14. Since Fluent 17 it needs 2 arguments (domain and check (which is a boolean variable)).
Here is a simple UDF for looping on all particles in each cell.
DEFINE_ADJUST(Looping, domain)
cxboolean count;
cxboolean check;
Thread *t;
cell_t c;
Particle *p;
Alloc_Storage_Vars(domain, SV_DPM_PARTICLE_BIN, SV_NULL);
bin_particles_in_cells(domain, count);
thread_loop_c (t,domain)
begin_c_loop(c, t)
begin_particle_cell_loop(p,c,t)
/* you can do your calculation on particles in one cell here*/
end_particle_cell_loop(p, c, t)
end_c_loop(c, t)
unthread_particles_to_all_inj(domain, check);
Free_Storage_Vars(domain, SV_DPM_PARTICLE_BIN, SV_NULL); /* release allocated memory*/
Old   July 3, 2018, 02:28
FENG
fyx1995 is on a distinguished road
cxboolean count;
cxboolean check;
Thread *t;
cell_t c;
Particle *p;
begin_c_loop(c, t)
end_c_loop(c, t)
hi!i‘m wondering is this udf suitable only for unsteady particle tracking
fyx1995 is offline   Reply With Quote
Old   July 3, 2018, 02:41
massoud
I have never used it for steady state. But, I guess if you use it for steady state it should loop over the streams passing from each cell.
[OpenFOAM.com] erros in Allwmake jiwon OpenFOAM Installation 7 December 30, 2015 12:34
text command problem hamed_roozegar FLUENT 1 May 27, 2009 03:00
Problems of running the parallel computations lorraine FLUENT 17 July 6, 2007 08:08
PVM Distributed problem - error connecting zaidun CFX 2 July 5, 2006 09:59
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
