Very high or negative pressures
Old   July 23, 2009, 16:42
Default Very high or negative pressures
jpo
jpo is on a distinguished road
Dear All,
I am modeling a pipe with dynamic mesh. One end is a piston, the other end is an outlet/outflow.
Case setup: k-epsilon incompressible: air density = 2.33 kg/m^3 = constant.
Operating pressure = 265kPa at piston; also tried 0 Pa.
I tried the open pipe end as outlet as well as outflow.
The first step of the motion ends always with wrong static pressures. Next to piston they are very high (>1E+6). If the open end is an outflow, then the pressure there becomes negative.
Please help me correct the errors in this case.
jpo is offline   Reply With Quote
Old   July 24, 2009, 01:33
-mAx-'s Avatar
Maxime Perelli
*switch to pressure-outlet
*check your units (scale)
*what kind of method are you using for moving mesh (layering/remeshing/...)
display the grid while plotting the pressure, and check if the high pressures aren't linked with bad cells
Old   July 24, 2009, 11:26
jpo
Hello mAx,
thank you for your time.
* switched to pressure outlet, still calculated static/absolute pressure at piston is > 1E+7
* my pressure unit is Pa
* I am using layering, it is a hex mesh on a rectangular pipe
* equiangle/equivolume skew is < 0.2
Old   July 24, 2009, 12:19
-mAx-'s Avatar
Maxime Perelli
*check the scale: grid/scale
*how fast is your piston moving?
*do you see any discontinuity in the fluid domain (display pressure)?
*does the fluid flows out?
Old   July 24, 2009, 13:49
jpo
* grid/scale: all scales = 1, unit = [meter]
* piston moves with 32 m/s
* no discontinuity: pressure is 265kPa at outlet and grows smoothly to 5E+7 at piston
* mass flux at outlet converged to -8.5kg/s
Pipe/duct has rectangular cross section, 0.3m x 0.1m, length ~20m
Old   July 24, 2009, 14:00
-mAx-'s Avatar
Maxime Perelli
post a picture with pressure and grid.
did you check the mesh motion?
Old   July 24, 2009, 14:14
jpo
Yes, the mesh motion is fine.
If the time step is dt=1E-4, mass flux at outlet is -8.5kg/s, pressure at piston is 5E+7Pa
If the time step is dt=1E-6, mass flux at outlet is -600kg/s, pressure at piston is 3E+11Pa
This is totally bogus. Something seems to be conceptually wrong.
Old   July 24, 2009, 14:21
-mAx-'s Avatar
Maxime Perelli
disable the MDM, switch to steady solver.
Change your moving piston to massflow inlet and give the 8.5kg/s.
Iterates and check the pressure distribution.
are you working 2d or 3d?
Old   July 29, 2009, 19:43
jpo
Apologies for the delayed reply.
Solution:
start the simulation with ideal-gas on, run for sufficient number of time steps. Switch to incompressible.
It works now.
Many thanks, mAx for the useful analysis; it has helped me tackle the problem from many aspects.
Cheers,
-jpo
Negative pressures in the flow domain mahut FLUENT 2 September 27, 2007 05:07
dynamic mesh, negative absolute pressures Jason FLUENT 0 March 15, 2005 09:36
