How to define a temperature-dependent specific heat in Fluent?
Old   July 24, 2009, 17:11
Question How to define a temperature-dependent specific heat in Fluent?
James Zhong
James is on a distinguished road
Hi, Fluent users:
I want to use UDF to define temperature-dependent specific heat in Fluent. Which udf should I use? I thought of DIFINE_PROPERTY. But in the manual, it doesn't mention specific heat can be defined. Thank you for your help in advance!
James
James is offline   Reply With Quote
Old   July 11, 2013, 13:30
poroshat is on a distinguished road
For defining specific heat you should use a different macro. It should be defined a Define_Specific_heat. You can find more details in the following pages:
http://www.sharcnet.ca/Software/Flue...udf/node51.htm
http://www.cfd-online.com/Forums/flu...ific-heat.html
poroshat is offline   Reply With Quote
Old   July 11, 2013, 14:37
Far
Sijal
Define a piecewise linear function for your range of temperatures and corresponding known cp values.
Calculation of heat generation in Fluent for 2D krishnachandranr FLUENT 0 April 7, 2009 23:31
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
how to impose experimental dat as boundary conditi Rogerio Fernandes Brito FLUENT 14 November 25, 2008 05:47
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 10:19
heat transfer coefficient Peter Main CFD Forum 7 August 26, 2001 18:44
