constant volume pump bc udf
Old   July 29, 2009, 06:58
Default constant volume pump bc udf
Adam R
Adammada is on a distinguished road
I need to create a boundary that works like a constant volume pump. Meaning at a multiphase outlet a fixed volume flow rate has to be removed (indiscriminate of phase) . I have done this manually using a pressure outlet with a negative gauge pressure but I want a automatic version that reads in the volume flow rate out of the boundary then adjusts the gauge pressure to achieve a pre defined volume flow rate. Has anyone done anything simlar or has an simlar example udf.
Thanks Adam
Adammada is offline   Reply With Quote
interDyMFoam - change in volume fraction gopala OpenFOAM Running, Solving & CFD 0 April 27, 2009 10:46
Constant Volume Chamber - Combustion and Ignition KOchzg FLUENT 0 March 30, 2005 10:19
COmbustion in constant volume chamber KOchzg Siemens 1 November 24, 2004 06:36
udf for repatching a temperature in a volume McGregor FLUENT 4 April 10, 2003 04:28
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
