[Question]About batch job
Old   August 3, 2009, 09:22
Unhappy [Question]About batch job
nickeet
fluboy is on a distinguished road
Recently, I had a problem in using batch file. I put three files(*.cas,*.jou and *.bat) in the same folder.
The matter in the journal file is as below
(cx-gui-do cx-activate-item "MenuBar*ReadSubMenu*Case & Data...")
(cx-gui-do cx-set-text-entry "Select File*Text" "3dchannel.cas")
(cx-gui-do cx-activate-item "Select File*OK")
(cx-gui-do cx-activate-item "MenuBar*SolveMenu*Iterate...")
(cx-gui-do cx-set-integer-entry "Iterate*Table1*Frame2(Iteration)*Table2(Iteration )*IntegerEntry1(Number of Iterations)" 2000)
(cx-gui-do cx-activate-item "Iterate*PanelButtons*PushButton1(OK)")
(cx-gui-do cx-activate-item "MenuBar*WriteSubMenu*Case & Data...")
(cx-gui-do cx-set-text-entry "Select File*Text" "3dchannel.cas ")
The matter in batch file is just one line:
fluent 3d -g -i *.jou
When I execute the batch file, the warning('fluent' is not the inside or outside command...) would appear. So, please direct me the way to make the batch file running.
fluboy is offline   Reply With Quote
Old   August 3, 2009, 16:54
Micael
Micael is on a distinguished road
With such a journal you also open 3dchannel.dat. Be sure it is there too.
Otherwise, that works for me (I'm with Windows ). This is what I put in the batch file (I used a 2D model):
fluent 2d -g -i journal.jou
Also, you can simplify your journal. This is equivalent to yours:
rc 3dchannel.cas y
rd 3dchannel.dat y
it 2000
wc 3dchannel.cas y
wd 3dchannel.dat y
Micaël
Micael is offline   Reply With Quote
Old   August 12, 2009, 11:10
nickeet
Dear Micaël :
Thanks for your guiding
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
FLUENT Batch job Saravanan FLUENT 11 May 14, 2014 16:47
How to specify the iterations of a batch job Consol Main CFD Forum 0 October 18, 2008 23:42
Running Job in Batch mode (EFD) Nick Sessions FloEFD, FloWorks & FloTHERM 0 April 16, 2008 16:44
Batch job M. Malik Main CFD Forum 6 February 12, 2008 09:49
