Cannot create surface from sliding interface zone |
August 9, 2009, 05:53 |
Jaruwan Tangtonsakulwong
Dear all
I've got this warning when displaying the grid '' Note: zone-surface: cannot create surface from sliding interface zone. Creating empty surface." and some wall surfaces does'n show in my graphic window. Anybody who know what is the course of problem and how to fix it, suggest me please. Many thanks in advance. Jackie |
August 27, 2010, 02:23 |
how to fix?
#2 | |
mustafa
dear jackie
i have same problem now and i ve couldnt solve it yet. can you help me how to fix it. Quote:
May 9, 2013, 09:25 |
#3 | |
Sumer
Rep Power: 15 |
Does any one know the fix for this problem?
July 1, 2013, 15:07 |
Serzh
Rep Power: 13 |
Usually this happens when you create an interface between two domains (define/mesh interfaces...), but usually this will not cause a problem. From Fluent 13 user manual "33.8.1 Create/Edit Mesh Interfaces Dialog Box":
"...Boundary Zone 1, Boundary Zone 2 display the names of the wall boundary zones that ANSYS FLUENT creates during the creation of a non-periodic mesh interface. If the two interface zones overlap each other, then the wall boundaries are created but with zero faces..." |
July 2, 2013, 02:42 |
#5 | |
Sumer
Rep Power: 15 |
This may not be the serious issue. At first sight it seems rediculous. But, try to solve the problem, ignoring the note, and, after few iterations, view your results in tecplot. You will notice that they are there. Regards.
December 28, 2013, 04:13 |
starter
Rep Power: 15 |
Deal All
I have the same issue when I connect a pipe tee with another pipe. How can I remove. Kindly advise. Regards |
June 6, 2017, 19:42 |
Victor Romero
May be you need to go to Design Modeler to check if you forgot to create a part for all your volumes. This could happen when you create several volumes and export them as independen parts.
I hope this could help you. |
empty surface, interface, sliding |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
conversion of a surface to a zone | ROOZBEH | FLUENT | 0 | April 14, 2008 11:26 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
about Sliding Interface | Jlucheng | FLUENT | 0 | August 23, 2001 20:40 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
