Wing Performance
Old   August 10, 2009, 16:08
Default Wing Performance
ANIL
makaero is on a distinguished road
Hi
I am working on 3D wing analysis, I have modeled a wing and subtracted it from a rectangular volume and meshed it with 1 million cells using Gambit.
To run the simulation in fluent
what boundary conditions should i use?
In post processing, what data i can get from fluent to analyse the performance of wing?
thanks for ur time....
makaero is offline   Reply With Quote
Old   August 10, 2009, 17:07
Troy Snyder
tas38 is on a distinguished road
If your flow is subsonic, the farfield boundaries can all be specified as velocity inlets and the outflow specified as a pressure outlet.
Alternatively, if the flow is trans/supersonic, you will want to specify pressure-farfield boundary conditions for all of the farfield boundaries. Doing so will permit you to specify a mach number and flow direction on those boundaries. The energy equation and ideal gas model must be activated for trans/supersonic flow. The boundary conditions may also be specified in this manner for subsonic flow and should not produced noticebly different results given that the Mach number is small.
See the fluent tutorial from external compressible flow. I believe the geometry is two-dimensional but it will provide a basis for setting your boundary conditions.
With regard to the wing, the boundary condition should be specified as wall. If no viscous model is activated, the walls will be specified with a slip condition automatically.
Postprocessing your model within Fluent:
It is possible to gather lift, drag, and moment coefficients as well as pressure coefficients along the upper and lower surfaces of the wing within Fluent.
tas38 is offline   Reply With Quote
Old   August 11, 2009, 17:01
Smile
ANIL
Yes the flow is subsonic....i wil try with that BC's
Thanks!
3D Wing Analysis Ed FLUENT 5 April 13, 2019 13:07
3D Wing Analysis Ed FLUENT 13 July 26, 2014 05:12
Forward swept wing simulation abid Siemens 1 June 16, 2012 13:26
Delta Wing Structured Grid Riaan FLUENT 3 December 31, 2004 12:03
Ansys/Flotran 3D Wing Analysis George Main CFD Forum 0 January 29, 2002 09:44
