Turbulent viscosity
Old   August 19, 2009, 08:50
Default Turbulent viscosity
nassim swlyman
eng.nassim is on a distinguished road
hi every body
I'm working on modeling of V.A.W.T for my thesis the problem is that the wake is too much small and every iter I have this message "Turbulent viscosity is limited to Turbulent viscosity in xxxxxxx cells " what this message means and what its effect on the solution and also how can resolve it.
if any body have an idea
thanks
eng.nassim is offline   Reply With Quote
Old   August 19, 2009, 11:04
tstorm is on a distinguished road
The turbulent viscosity ratio is the turbulent viscosity / laminar viscosity (mu_t/mu_l).
The problem COULD be a number of things. Usually, it's either a poor mesh (skewed cells, large changes in cell size, or cells are too big,) or bad boundary conditions. If the boundary conditions are correct, try refining the grid in the region where the TVR is limited (go to adapt, then gradient.)
tstorm is offline   Reply With Quote
Old   August 19, 2009, 11:18
Post To change the property of limit
Jung-ryun Lee
Ryun is on a distinguished road
I encoutered similar problem of yours, actually in my case, I faced
"Temperature is limited~~~" message.
In FLUENT menual - I can`t exactly recall the section regarding this
matter, In this case, FLUENT may lead inaccuracy result.
In conclusion, I solved it by changing the value of Tab of
SOLVER > LIMITS > TEMPERATURE> 5000
initial temp limit is 5000, but I changed it up to 500000000
There is no serious estimation but just increasing the range of FLUENT
computation upper limit.
So that, FLUENT can use more higher temperature value to calculate.
So, similarly, I recommend you to change the initial value of TURBULENCE
LIMITATION
at the SOLVER > LIMIT > turb - initial value
BUT, THIS IT JUST MY THINGKING.
Hope this helped you~^^
Ryun is offline   Reply With Quote
Old   August 19, 2009, 11:26
Ryun,
I don't know what material you're working with, but the temperature limit exists to keep your solutions feasible. Temperatures on the order of 500000000 are not realistic for CFD, so increasing the limit to allow temperatures this high will not yield physically accurate results.
There's been discussion before about the correct limit for the turbulent viscosity ratio though, and a limit like 1e6 is certainly realistic. That may help if you're dealing with high Reynolds number flows there the TVR may actually reach a million, but usually the TVR limit (and probably temperature limit) are due to BCs or grid issues.
Old   August 19, 2009, 11:41
Default Yes. you`re right.
Jung-ryun Lee
Dear TSTORM.
Thank you for your correction. and I learned that one in this time.
I didn`t consider the grid, or BC condition factor.
When I`m writing the reply hardly in english, your reply is updated earier.^^
Then, I look your advice, it is more hard fact.
So, probably my solution may be also possible to fail.
fluent, trublance, wind turbine
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 00:05
Turbulent viscosity in a riser ap FLUENT 8 April 19, 2003 08:00
effective? turbulent? laminar? viscosity MIssNancy FLUENT 3 December 2, 2002 23:53
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
Turbulent viscosity Christian Holm Main CFD Forum 4 June 23, 2001 22:04
