Urgent Help !!!Strange reverse flow in naca0012 problem |
August 30, 2009, 02:17 |
parvez
Rep Power: 17 |
Hi Friends,
I am trying to simulate flow over an airfoil NACA0012 with chord C=20mm. I have made the grid with 114400. But when I am trying to simulate it in Fluent First thing it gives me a warning: The mesh contains very high aspect ratio hexahedral or polyhedral cells. The default algorithm used to compute the wall distance required by the turbulence models might produce wrong results in these cells. Please inspect the wall distance by displaying the contours of the 'Cell Wall Distance' at the boundaries. If you observe any irregularities we recommend the use of an alternative algorithm to correct the wall distance. Please select /solve/initialize/repair-wall-distance using the text user interface to switch to the alternative algorithm. but since I am using laminar flow I discard the warning and started simualtion with left top and bottom farfield as velocity inlet and right farfield as outflow but it is giving me a reverse flow at the outflow face 4 at the very starting of the iterations only . What should I do? I am really stucked with this problem and I soon have my defence I need to complete this asap. I can mail my case file if needed. Thanks PARVEZ |
August 31, 2009, 16:24 |
Troy Snyder
Rep Power: 18 |
It sounds as if the mesh quality may be poor. The aspect ratio in some of the cells near the boundary my be too high. If you could post your mesh, that would be great.
tas38 |
August 31, 2009, 22:22 |
Reverse flow: uploaded pictures
parvez
Rep Power: 17 |
Thanks a lot for the reply....I have attached the file links please see.
http://img10.imageshack.us/i/25241961.jpg/ http://img206.imageshack.us/i/97161438.jpg/ http://img206.imageshack.us/i/31751490.jpg/ http://img206.imageshack.us/i/81466775.jpg/ |
September 1, 2009, 15:29 |
Troy Snyder
Rep Power: 18 |
It looks as thought the grid was constructed with a boundary layer attached to the airfoil surface. Is this the case?
Additionally, I would focus attention on cells near the farfield. The increasing grid density near the farfield can result in high aspect ratio cells. Additionally, if the cells are non-orthogonal to the farfield boundary, they can become highly skewed. Could you post pictures of the farfield boundary near the trailing edge of the airfoil and projected "upwards" -- near where the semi-circular edge and straight edge of the farfield boundary meet. |
September 1, 2009, 19:26 |
Chris
Rep Power: 16 |
You might be getting reversed flow because you have a face with an inlet boundary condition directly adjacent to a face with an outlet boundary condition. What happens (possibly) is that the flow from the inlet, when it enters the domain, pulls flow in through the outlet. Since you have flow "the wrong way" at the outlet face, FLUENT warns you that you have reversed flow.
May 20, 2013, 09:25 |
Reversed flow
#6 | |
Nisha
Rep Power: 16 |
Yes, so was it for my case. Edited the mesh, reduced the aspect ratio, and it worked. Thanks. |
Complex problem: Open Channel Flow | lett | FLUENT | 18 | November 10, 2018 18:30 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
Flow not moving - Supersonic/Initial Pressure problem? | shankara.2 | FLUENT | 0 | June 9, 2009 20:49 |
transient compressible flow problem (urgent plz) | jehanzeb | FLUENT | 5 | August 3, 2004 08:04 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
