nickeet
Rep Power: 16 ![]() |
Dear all
I had a problem about calculate convection coefficient "h". Because I don't know the "h" of my model, and I want to calculate the "h" by using "Fluent" If it is possible, how should I do? Please direct me, thanks. |
JP
Rep Power: 18 ![]() |
I guess that you want to calculate the heat transfer coefficient at a wall surface.
You can do it from the 'Report' option in post processing. Report > Surface Integrals Select "Area weighted average" under report type. Select "Temperature > Surface Heat Transfer Coef." under "Field Variable" Select your surface and click "compute" All this, provided you had turned on your Energy Equation, and given proper thermal boundary conditions. |
nickeet
Dear srjp, thank you very much.
The answer is what I need. I just need the surface h to be used in the boundary condition of energy equation. |
how to calculate heat transfer coefficient | kathiravan | Siemens | 10 | May 5, 2017 16:04 |
About calculation of convection coefficient | fluboy | FLUENT | 0 | September 10, 2009 10:57 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
heat transfer coefficient - forced convection | Tes | Siemens | 2 | April 16, 2005 18:14 |
User Defined Function for convection coefficient | ereiss | FLUENT | 1 | July 8, 2004 16:10 |
