Warning: ST_Malloc: out of memory.malloc_storage |
October 9, 2009, 10:52 |
Ivan
Rep Power: 16 |
I am running a 3ddp case, meshed using GAMBIT and then exported to FLUENT. The number of cells of my grid is 2160000. Its giving me the following error [b:60a77ba75e][color=blue:60a77ba75e]Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Z Velocity Gradient, size 92651040, t 2, myid 1000000. Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Body Force, size 92651040, t 2, myid 1000000. Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Body Force Corr, size 92651040, t 2, myid 1000000. Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Mass Flux, size 61298560, t 9, myid 1000000. Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc f_a1, size 30649280, t 9, myid 1000000. Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()[/color:60a77ba75e][/b:60a77ba75e] ------------------------------------------------------------------------------ My system is a Windows XP 32 bits with 4 GB of RAM, although the Memory Status application of Fluent says that I have got 2004012 KB of physical memory plus 2047724 KB of page memory. Anyone who have some idea please help me. Many thanks, Ivan. |
October 9, 2009, 13:24 |
Akour
Rep Power: 17 |
hi,
anything over 1 million cells requires a fluent parallel solver. check if your PC has multiple processors, and then issue the command fluent 3ddp -tx where x is the number of processors you have. various things change when you run fluent in parallel so i recommend you consult the manual. otherwise, ule need to get your hands on a cluster! akour
akour |
access_violation, malloc, out of memory, st_malloc |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit | coompressor | OpenFOAM Installation | 0 | November 12, 2008 19:53 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
