Elias Montoya
Rep Power: 16 ![]() |
Hi, I am a newbie on UDFs and I have a problem that maybe is easy or even for some of you who have a lot of experience.
From the fluent's UDF manual I copied an example and changed a function to get the following UDF /************************************************** ******************** unsteady.c UDF for specifying a transient velocity profile boundary condition ************************************************** *********************/ #include "udf.h" DEFINE_PROFILE(unsteady_velocity, thread, position) { face_t f; real t = CURRENT_TIME; begin_f_loop(f, thread) { F_PROFILE(f, thread, position) = 0.5*t; } end_f_loop(f, thread) } It works when I run it in serial fluent, but it does not work when I try to run the simulation in parallel fluent. I have read the manual but I honestly dont know how to make it work. It would be great if someone told me what should I add or change to make it work for parallel fluent. Thanks for any reply, Elias |
Rep Power: 17 ![]() |
That doesn't look like it will need any special treatment to run in parallel.
You will have to compile the library in parallel fluent though (you can't compile in serial and load that library in parallel.) |
Elias Montoya
tstorm, Thank you very much for your reply. I think I was having a problem with the compiler or something like that. I have tried in another computer and nw it worked.
Thank you anyway. |
parallel, transient, udf |
Help, parallelizing UDF problem. | blivurmind | Fluent UDF and Scheme Programming | 2 | July 24, 2009 11:40 |
Help, parallelizing UDF problem | blivurmind | FLUENT | 0 | July 9, 2009 21:39 |
Multi step transient UDF velocity profile problem | William177 | FLUENT | 1 | February 3, 2008 06:47 |
spatial and transient B.C. using UDF | Park | FLUENT | 0 | April 28, 2005 21:32 |
UDF for transient boundary condition? | Shankar | FLUENT | 1 | November 22, 2003 08:10 |
