October 19, 2009, 12:50 |
Boussinesq Assumption
I've read that the Boussinesq assumption linearized the relationship between the turbulent stresses and the mean strain rate, so: u_i*u_j=2/3*k*del_ij - 2*nu_t*S_ij I've also seen people say that the Boussinesq assumption makes the normal stresses isotropic, so: uu=vv=ww=2/3*k My question is where does the second term go? Does the Boussinesq assumption also assume that du/dx = dv/dy = dw/dz = 0? Thanks! |
October 22, 2009, 08:57 |
JP
Rep Power: 18 |
When the normal stresses are made isotropic, the first term vanishes and you have the linearized equation for the turbulent shear stress (second term)
as: tau_xy = mu_t * du/dy where mu_t is the turbulent viscosity |
October 22, 2009, 10:12 |
Thanks, but why does the first term vanish? It should vanish if the Kronecker delta is zero, which happens for the off-diagonal terms, not the diagonal terms.
I'm clearly still confused. I appreciate your help! |
October 26, 2009, 05:11 |
Krishna
Expression for Tou ij =2*mue_t*Sij-2/3*k*rho*del_ij; Sij=2(dui/dxj+duj/dxi)----------Terms here are time averaged. When i=j; Sii=0 for incompressible flows. Recollect the time averaged continuity equation. |
Natural Convection in a storage tank - boussinesq? | Jervds | CFX | 6 | October 2, 2016 02:53 |
Density boussinesq Problem | matrix-1.0 | FLUENT | 9 | January 17, 2014 21:17 |
Boussinesq | lucifer | FLUENT | 0 | September 26, 2009 09:31 |
Boussinesq - natural convection | Jeremie | FLUENT | 2 | March 8, 2007 08:12 |
GAMBIT: Assumption of an edge type while meshing | Agnes | FLUENT | 0 | June 22, 2005 13:37 |
