How work with grid interface??
Old   October 22, 2009, 00:42
Question How work with grid interface??
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Hi All,
In Modeling airfoil, I want to just make some variation of Angle of Attack. I hear that Grid Interface can make my job simpler. i read in tutorial of FLUENT there is correlation with TGRID. But i don't understand how it works. can you tell me How to make simulation by using grid interface??
teguhtf
teguhtf is offline   Reply With Quote
Old   October 22, 2009, 02:16
-mAx-'s Avatar
Maxime Perelli
You need to have 2 separated zones which are not connected.
At the interface between the 2 zones, you will have 2 superposed entities (edge for 2d, surface for 3d).
Just define each entity as separated interface. Then in Fluent, define the couple of interfaces (define/interfaces)
In your case, you create a circle around your airfoil, the interfaces will be the 2 superposed circles.
Check Help (11. Modeling Flows Using Sliding and Deforming Meshes)
Old   October 22, 2009, 12:44
Exclamation
teguhtf's Avatar
teguh hady
Thanks For your response. I've tried. But i doesnt work. Here is my file. I jut want to rotate my foil.
http://rapidshare.com/files/29645441...RFACE.rar.html
Thanks for your help!!!
teguhtf
Old   October 22, 2009, 13:55
-mAx-'s Avatar
Maxime Perelli
Will check it on Monday
Old   October 26, 2009, 01:55
-mAx-'s Avatar
Maxime Perelli
I check the dbs file and it is alright regarding the interface definitition.
So you shouldn't have proble to define them in fluent.
What kinds of error do you get?
2 points on your gambit session.
* your mesh should be refined around your moving body (in your case the mesh get coarser near the body)
*you have to define the rotating domaine (surface) as separated fluid domain, because you will also rotate this region
Old   October 26, 2009, 04:59
Question I'm not using dynamic meshing!!!
teguhtf's Avatar
teguh hady
In my case, i don't use dynamic mesh in rotating things. I use Grid Interface to make my geometry become less than make geometry in each angle of attack. I hear that in ANSYS, I just make 2 geometry to complete my Angle of attack (I mean geometry of circle & rectangle and I just rotate my circle by using grid interface).
I'm sorry if my mesh is very poor. My focus on meshing is objected in quality of meshing. I don't know what is the best meshing!!
teguhtf
Old   October 26, 2009, 05:36
-mAx-'s Avatar
Maxime Perelli
Ah ok, I thought you wanted your airfoil rotating. Sorry.
So you just have to rotate you middle surface in Gambit with your specific angle, and then export your mesh.
I have no idea with Ansys.
Regarding your mesh, and especially your grid interface, the mesh in this region has to be +/- with the same size.
Best mesh is always quad/map, but the question is: can you afford spending many days trying to mesh your model with full hexa.
In your case, don't hesitate you can easy mesh your stuff with hexa
Old   October 26, 2009, 06:36
Red face
teguhtf's Avatar
teguh hady
yes, I'll try it!
In this problem, I use 2D solver. By the way, what is the meaning of "Regarding your mesh, and especially your grid interface, the mesh in this region has to be +/- with the same size"??
Is it meaning that the meshing of interface one and other must similar??
thank you very much!!
teguhtf
Old   October 26, 2009, 06:44
-mAx-'s Avatar
Maxime Perelli
not exactily similar, but not 5x bigger (resp. smaller).
Old   October 27, 2009, 04:58
Arrow
teguhtf's Avatar
teguh hady
I'll try it.
Anyway, do you know the basic calculation of FLUENT in computing Lift Coefficient in 2D?? because There is no Area in 2D.
Thank you!!
teguhtf
Old   October 27, 2009, 05:35
-mAx-'s Avatar
Maxime Perelli
I assume you have to enter a reference length in place of the area.
The coeff will be still dimensionless, as the force is computed on an edge (and not a surface)
Old   October 28, 2009, 21:48
Question what is voume statistic in FLUENT 2D
  #12
teguhtf's Avatar
teguh hady
Thanks, by the way. when i use FLUENT 2D there is volume statistics when i check my *.msh. what is that?? I have thought before that the value of Cl based on that volume.
teguhtf
Old   October 29, 2009, 01:56
-mAx-'s Avatar
Maxime Perelli
check Mesh is only informations about your mesh topology/quality/etc...
No link with Cl
grid, interface
Two problems about interface and refined grid peter.zhao FLUENT 0 August 21, 2006 10:59
Multiblock grid, interface Boundary condition Nandu CFX 2 August 6, 2002 05:07
Problem with grid interface Anindya FLUENT 9 July 26, 2002 16:04
Numerical methods for discontinuous grid interfaces? Hansong Hang Main CFD Forum 12 September 16, 1998 22:26
