Grid resolution for an airfoil with a Gurney flap
Old   October 24, 2009, 07:22
Default Grid resolution for an airfoil with a Gurney flap
alastormoody11 is on a distinguished road
I am simulating a 2D airfoil with a Gurney flap(which is a thin flap, extending on the suction side attached to the trailing edge perpendicular to the camber). I am using a quasi steady approach and using the K-E(k- epsilon) turbulence model with a standard wall function. Now for an airfoil with a Gurney flap 2 counter rotating vortices are set up behind the airfoil and one more vortex is set up between the flap and the suction side. The problem is that for resolving these three vortices a very fine mesh is required due to which the wall y plus values in this region drop well below the recommended value(30 for standard wall fn and 5 for enhanced wall treatment) Is the use of the turbulence model still justified since I want the Cl(coefficient of lift) from this simulation or is there any other way out?
alastormoody11 is offline   Reply With Quote
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 03:33
Large difference in grid resolution for diff paper Ben Main CFD Forum 16 April 7, 2007 11:45
Meshing An airfoil with a simple plain flap S. Kalam FLUENT 7 January 30, 2005 20:22
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
