Labyrinth Seal (Axisymetric swirl flow)
Old   November 9, 2009, 20:42
Default Labyrinth Seal (Axisymetric swirl flow)
Sangkwon Na
nasa0402 is on a distinguished road
Hi everyone,
I'm trying to solve sudden constricted channel flow with air, whose height and pressure differences are 0.15 mm and 5 to 3~10 bar for the general labyrinth seal. The diameter of a rotating shaft is 400mm and its speed is about 30000 rpm.
I applied pressure based 2D Axisymetric swirl to this problem and it converged very well up to about dp 1 bar between the inlet and exit. But, it does not work any more as dp inceases over 1.5 bar even with density based solution. I understand that flow would be chocked and has highly increased Mach number and has lots of discontiuity at throat (or constricted channel) in physics, and it causes the problem diverged directly.
Please advice me how to sep up the modeling and any tutorials related.
Thanks,
nasa0402 is offline   Reply With Quote
flow patterening of axisymetric impinging jet sachin kulkarni Main CFD Forum 1 February 25, 2006 16:14
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
swirl flow, B.C. for exit? victor FLUENT 1 December 11, 2001 01:46
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 07:33
