Compiling UDF on a cluster
Old   December 8, 2009, 10:49
Default Compiling UDF on a cluster
Adya is on a distinguished road
Hello All,
I am trying to compile a UDF on cluster(multiple nodes). If I run Fluent interactively on the cluster it compiles fine and I am able to link the UDF files with the case file. But when I submit a job on the cluster I get an error that says the UDF file cannot be found. My job file looks like this:
/file/rcd/nethome/users/sa5kb/SJA/Case1/test/Case1-finemesh.cas
/define/user-defined/compiled/compile/libudfyes vel_piston.c""
/define/user-defined/compiled/load/libudf /nethome/users/sa5kb/SJA/Case1/test/libudf/lnamd64/2ddp/libudf.so
/solve/iterate 10000
/file/wd /nethome/users/sa5kb/SJA/Case1/test/Case1-finemesh.dat
/exit
This job file compiles the C program but is not able to find and link the compiled UDF with the case file. Is there anything wrong in the way I am doing it?
Adya is offline   Reply With Quote
Old   December 14, 2009, 11:30
Michele Vascellari
mighelone is on a distinguished road
I have never compiled udf, during a job, so I'm guessing....
from which path do you launch your job? Do you move to the working directory in the script file, otherwise the working directory is the home.
Probably fluent compiles the udf library in the home directory o somewhere else.
Try to look up the libudf directory generated during compilation, using
find $HOME -name "*libudf*"
regards
Michele
mighelone is offline   Reply With Quote
udf compilation
problem loading UDF library in parallel cluster Veera Gutti FLUENT 8 July 26, 2016 07:24
UDF compiling problem in Flient 6.3 jeevan kumar FLUENT 2 February 25, 2009 00:43
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
Help: how to realize UDF on parallel cluster? Haoyin FLUENT 1 August 6, 2007 13:53
On Compiling a UDF David Chabot FLUENT 5 May 20, 2005 09:13
