Non converging simulation
Old   December 22, 2009, 10:15
Default Non converging simulation
ghost is on a distinguished road
Hi, I have setup a 2D flow over an aerofoil, with some blowing along the top leading edge.
I ran the test using the k-e model, steady state, courant number 0.5.
After 200000 iterations, fluent still does not show that it has converged. The residuals are fluctuating about a mean value, with the continuity decreasing at a very slow rate. It is still at order of e-3.
A plot of the lift and drag coefficient shows that they are increasing at a very slow rate, almost flat from the the zoom out view.
Can I assume that the values have converged, since I am only interested in getting the lift and drag coefficient values? Or is there any method that I can do to speed up the converging?
Thank you.
ghost is offline   Reply With Quote
Old   January 1, 2010, 22:27
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
you can repair your meshing. maybe there is bad quality. make your meshing near wall is smooth. because it'll take effect on your simulation.
hope it helps!!
Now Or Never!!!
teguhtf is offline   Reply With Quote
Old   January 4, 2010, 21:05
hope it helps!!
may i know how can i make the near wall meshing smooth?
usually i just mesh the face and check that the cells are not too skewed.
Old   January 5, 2010, 09:25
JaC
Jakub Broukal
JaC is on a distinguished road
if you use Gambit, you can do the boundary layer in the meshing tab - I thin its the first button. And if you use ansys mesher use the Inflation function.
Regards
Jakub B.
JaC is offline   Reply With Quote
Old   January 5, 2010, 09:31
i have always used the boundary tab on the near wall surface for all my simulations.
Old   January 5, 2010, 09:40
JaC
Jakub Broukal
Hi again,
in that case you can try to refine your mesh...if the problem persists you can rule out bad geometry as cause of your issue and check other things that may have caused it...
Maybe you could upload the picture of your mesh...
Regards
Jakub B.
Old   January 5, 2010, 10:00
here is a pic of the mesh at the injection area.
if someone is willing to help, i can send u the mesh file.
thx
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
NACA 4 digit simulation - not converging dublin CFX 2 April 24, 2009 07:27
Continuous vs interrupted simulation sega OpenFOAM Running, Solving & CFD 4 November 3, 2008 14:29
Fire simulation using FDS from NIST Jens Main CFD Forum 1 January 22, 2004 01:53
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 10:06
