discrete phase modeling-coupled or uncoupled?
Like Tree1Likes
  • 1 Post By MDinc
Old   January 10, 2010, 20:53
Default discrete phase modeling-coupled or uncoupled?
Mrt
MDinc is on a distinguished road
Hello Everyone,
I have 2D snowplow model to analyze the snow particles trajectories after rebound plow blade. There is going to be at least 30 cm snow in the ground and velocity will be 20 m/s for these snow particles (snowplow speed is 20 m/s).
My question;
1) Which calculation method should I choose in DPM- uncoupled or coupled?
2) Which turbulence model is most available for my model- k-e or RSM?
3) Could we solve discrete phase at the same time with the continuous phase?
Thanks,
Murat
wdridi likes this.
MDinc is offline   Reply With Quote
Old   January 10, 2010, 21:10
Default Dpm
CFDtoy
CFDtoy is on a distinguished road
Hi there,
to your questions
1. use DPM uncoupled - assumption: motion of snow particles does not influence air flow - dilute particles. Unless you have heavy particles (with high fraction) flowing in the continuous medium ....you can safely assume that snow follows the air movement.
2. for turbulence : RSM is effective..since the flow may contain recirculation behavior (this is more importantly based on your geometry) strain effects not well captured by k-e.
3. the dpm integrates partice motion with the continuous gas medium.
Hope this helps.
/CFDtoy
visit http://cfdtoy.blogspot.com
Originally Posted by MDinc View Post
Hello Everyone,
My question;
Thanks,
Murat
CFDtoy is offline   Reply With Quote
Old   January 25, 2010, 15:35
Mrt
Thank you for reply to my questions.
1. I was also thinking to apply ''uncoupled'' option for the DPM part. Your answer help me in this way.
2. Also, I will consider RSM Tur. modelling (especially for the 3D model)seeing that I have complicated and detailed snowplow truck geometry.
3. But, I still could not understand that if I should apply DPM modelling parameters (inert particles, densities, ....) after getting solution from the continuous phase or not?
Thanks,
Murat
Old   March 22, 2011, 07:16
Default Snow Avalanche
yashwant
saini.yashwant is on a distinguished road
hi
i am doing the snow avalanche problem so rt now i am using the snow as a fluid but as per the problem i have to model it as granular structure. so please suggest me how to model the snow in fluent to get the actual effect.
thanks
Hello Everyone,
My question;
Thanks,
Murat
saini.yashwant is offline   Reply With Quote
species transport and discrete phase modeling .... farhath FLUENT 2 February 11, 2006 01:09
uncoupled discrete phase calculations AMV FLUENT 0 December 3, 2003 07:21
Discrete Phase Modeling revanth FLUENT 8 July 18, 2002 05:30
Discrete Phase Modeling Fred Kang FLUENT 3 October 18, 2000 10:23
Discrete Phase Modeling X.Tang FLUENT 0 April 25, 2000 08:17
