January 20, 2010, 14:11 |
refining mesh instead of adapting mesh
François Grégoire
Rep Power: 17 |
I'm using ansys fluent 12.1.2.
Is there a way to refine the mesh without any adaption? Refine the mesh over the entire domain independently of the solution ? Why would I want to do that? I'm modeling turbulence in a complex geometry and I'm having a hard time with the y+ being in the acceptable range everywhere. I want to start with a coarse mesh, refine it in Fluent, this way I can coarsen back the mesh if my y+ are too low in some places. |
January 21, 2010, 10:24 |
Jouke de Baar
Rep Power: 16 |
There is. But this method is limited to a integer factor of refinement (2 is default). Do the following:
- let your model converge on the coarse mesh - adapt > region : enter a very large region that includes your complete domain (like x from -100 to 100 etc) and click 'Adapt' - continu your calcs on the now 2x refined mesh - check your y+ hope it helps, good luck! |
January 25, 2010, 14:03 |
François Grégoire
Rep Power: 17 |
thanks Jack,
It works just fine for refining the mesh. And it is possible to coarse the mesh back. |
August 5, 2010, 02:43 |
Grid Adaption based on Region (i..e using Adapt->Region)
Arnab Dasgupta
Hi all,
I am a new user to the world of CFD and FLUENT and am trying to refine my mesh using the grid adaption feature in FLUENT based on region. My model consists of an ellipse (representing a idealised wing) surrounded by a boundary layer consisting of quadrilateral cells, which in turn, is surrounded by triangular cells that form an O-shaped grid. A picture of the initial mesh is attached. Currently I have arround 60,000 cells but want to refine my mesh for grid-independence studies. As established above, I am attempting to use the grid-adaption feature within FLUENT based on region. Specifically I:
From a grid independence study point of view, where I should gradually increase the mesh resolution and see how much the solution (I am measuring lift and drag values generated by the wing btw) changes, I clearly need a few scenarios with differing mesh resolutions. At present I am at a loss on how to achieve this. Any advise or comments on this would be greatly appreciated. Thanks and Regards Arnab |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[Other] vtk mesh or Abaqus mesh to OpenFOAM | bigphil | OpenFOAM Meshing & Mesh Conversion | 27 | November 23, 2015 17:31 |
[mesh manipulation] Refining Mesh | vishal | OpenFOAM Meshing & Mesh Conversion | 0 | September 25, 2008 08:16 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
adapting mesh in FLUENT | Madhukar Rapka | FLUENT | 1 | June 22, 2006 15:59 |
