Flow is not converging in natural convection problem of boussinesq model for air
Old   January 25, 2010, 01:16
Default Flow is not converging in natural convection problem of boussinesq model for air
rahul
rahulsharma is on a distinguished road
hey guys
this is rahul working on cfd analysis of natural convection cross ventilation of a room inside a computational domain. the heat source is provided on a wall.
1. is it fine to define a heat source at wall in boundary condition panel as heat source W/m2
2. Solution is not converging than what should be the problem.
can anyone help me.
thanks,.
rahulsharma is offline   Reply With Quote
Old   December 15, 2015, 09:19
Radia
rlahlou is on a distinguished road
Hey rahulsharma,
did you finally solve your issue?
I am facing convergence issue as well using Fluent for a free convection problem in a side-heated vertical channel. When I use Boussinesq assumption with pressure inlet and pressure outlet BC, I get the AMG solver divergence ( Although I reduced the under-relaxation factors, checked the mesh quality and a bunch of other changes recommended on forums for AMG solver divergence ...).
Using the ideal gas law for density instead of Boussinesq, I obtain a solution but it is unphysical.
Thanks a lot for your (or anyone else's) feedback!
rlahlou is offline   Reply With Quote
Old   December 2, 2020, 18:19
DB
DB99 is on a distinguished road
Fluent does not converge well at low mass flow values.
DB99 is offline   Reply With Quote
Old   December 2, 2020, 19:05
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
If it's a closed domain (i.e. no inlets and no outlets) then it will struggle to converge.
JuPa is offline   Reply With Quote
Old   December 2, 2020, 21:07
DB
Yes, I have seen the Fluent solver claim to meet convergence criteria but if a conservation of mass flow is done, in vs out, there can be a large difference. Factor of 7 is not unusual. These were in the low CFM range (4.5 e-4 kg/s if I converted that right from memory) in somewhat confined spaces with arrays of electronic enclosure vents as inlet and outlets.
Ansys tech support said sorry, the flow is too low. FloTHERM XT and FloEFD do not have such problems.
Natural Convection in a storage tank - boussinesq? Jervds CFX 6 October 2, 2016 02:53
Natural Convection problem in Fluent - urgent NSV FLUENT 10 May 6, 2014 04:25
lenght and number of nodes for an orifice meter flow problem - k-eps model fofo FLUENT 0 November 15, 2009 03:49
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Boussinesq - natural convection Jeremie FLUENT 2 March 8, 2007 08:12
