Fluent 12.0, Low Reynolds Number Flows
Old   January 25, 2010, 17:14
Default Fluent 12.0, Low Reynolds Number Flows
Anand
anandvksin2003 is on a distinguished road
I am currently working on Flow simulation in Labyrinth seals using Fluent 12.0 at Texas A&M University College Station. I have the following queries:
I am using a fine mesh and hence Graphics window layout constantly refreshes the screen causing the application to slow down in Fluent 12.0. Every time i pick an option from a dialog, it rebuilds the graphic window layout. Is there any way i could get a Graphic window layout like Fluent 6.3.26 which would not refresh every time ?
Also i have turned on the turbulence models in my simulations, at high Reynold numbers the simulation work fine, however at low Reynold numbers in the laminar range i observer streamlines like in potential flow. Does Fluent 12.0 automatically turn off turbulence models at low Reynold numbers ? The streamlines almost follow the tooth profile in labyrinth seals at low Reynold numbers.
Thanking you,
Sincerely,
Anand Vijaykumar
Graduate Student,
Department of Mechanical Engineering,
Texas A&M University- College Station
anandvksin2003 is offline   Reply With Quote
Old   January 26, 2010, 05:16
Jouke de Baar
jack1980 is on a distinguished road
To know how much turbulence you have plot the turbulent intensity (http://www.cfd-online.com/Wiki/Turbulence_intensity), or perhaps turbulent viscosity ratio.
jack1980 is offline   Reply With Quote
Turbulence model for low Reynolds number flow? Nokadu Main CFD Forum 3 May 26, 2013 11:42
Low Reynolds Number Drag Law - UDF Daggemann FLUENT 0 April 30, 2009 05:02
low reynolds number K-epsilon model amar STAR-CD 2 March 23, 2009 07:24
Combination of high and low Reynolds number adolfo FLUENT 0 June 24, 2005 13:09
Low Re number flows Wu Chun-Kai Main CFD Forum 17 July 1, 1999 20:24
