why absolute pressure and temperature limited to 1.000000e+00?
Old   January 27, 2010, 15:51
Default why absolute pressure and temperature limited to 1.000000e+00?
wild
wildli is on a distinguished road
Dear all,
I am running a case of two counter rotating wheel in a chamber(adiabatic) to compress air (ideal gas), I am meeting the problem of absolute pressure and temperature limited to 1.00000e+00 for a lot of cells. Whenever I switched the air into constant density but keep energy equation on, there is no problem for the calculation; I checked the fluid characteristics, it looks like both wheels rotate very well, and give me some good result for constant density gas.
The problem lies in solving energy equation.
Can any one give me some hint how to overcome this difficult? it bothers for quite a while, any hint would be highly appreciated.
thanks!
Reference for the settings:
Geometry description starting from the inlet flow:
1. flow inlet --> front chamber flowing zone --> 1st axial impeller(rotating) --> small gap before 2nd wheel --> 2nd wheel(counter rotating) --> back chamber flowing zone --> outlet
2. all of these flowing zone sections have the same out diameter
ANSYS 12-FLUENT
1. Pressure-based, absolute velocity formulation, steady case
2. viscous model selected as standard k-e
3. material selected as idea gas with specific Cp, viscosity
4. fluid inside of two wheels specified as moving reference frame
5. pressure inlet, pressure outlet with static pressure and backflow temperature specified,
6. two impeller wheel are chosen as moving wall which have 0 relative velocity to the adjacent zones.
7. faces between rotating wheel zone and fluid flowing chamber zone are interface
8. simple scheme with least square cell based gradient, and 1st order wind for other parameters
9. URF are set as default
wildli is offline   Reply With Quote
Old   January 28, 2010, 01:25
mas
Mas
mas is on a distinguished road
I'm sure you'll find many answers to that question in this forum if you search. Generally, I think you should increase the quality of your mesh.
<Mas>
mas is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
temperature limited - absolute pressure limited Asashi FLUENT 3 July 18, 2014 09:51
Absolute Pressure and temperature limited to...... Shamoon FLUENT 1 August 31, 2007 15:09
pressure and temperature limited Radwa FLUENT 2 July 3, 2006 00:19
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
