Mismatch between Fluent Surface Integrals Report and Surface Line/Rake Tool
Old   March 31, 2010, 11:21
Default Mismatch between Fluent Surface Integrals Report and Surface Line/Rake Tool
Emily
emlejeen is on a distinguished road
I am simulating an axi-symmetric tube where I am applying a constant flow rate to the inlet of the tube. I have written a UDF that expands a bulb that is attached to the bottom of the tube. The inlet is stationary and the tube is deforming. The UDF is working properly, but when I try to compare the velocity at the inlet at various times, I have a discrepancy.
When I look at the surface integrals and show the average facet velocity on the inlet surface, I have an average velocity of 0.0082 m/s. However, when I plot a rake across the center of the inlet, I calculate an average of 0.0114 m/s. For arguments sake, I have also integrated the function of the velocity profile to account for non-uniform concentrations of the velocities when taking a random rake. I believe I should be able to do this because my inlet is a circle and does not change throughout the solution.
I have tried comparing the surface integrals with the rake/line tool at various times and I am still seeing the incorrect trend.
Any suggestions/explanations?
Emily
emlejeen is offline   Reply With Quote
inlet velocity, rake, surface integrals, velocity
Surface integrals report: incident radiation Novice FLUENT 3 February 8, 2018 09:53
Total Heat Transfer Rate & Total Surface Heat Flux Mismatch icaro FLUENT 0 November 24, 2009 07:01
report surface area WITHOUT solit Ralf Schmidt FLUENT 1 June 1, 2007 10:23
monitor surface integral & report surface integral Ning FLUENT 0 March 18, 2007 12:51
