May 16, 2010, 18:15 |
convergence problems by species transport
Felipe B. Ch.
Rep Power: 16 |
Hi, I hope any one can help me
I am simulating a free jet injection of hydrogen in two points in co-flow with air in a cylindrical mixing tube. First I run the simulation just with air and it has a good convergence. When I activate the option of species transport(using a Kinetic Mechanism from Chemkin), all the residuals go down except the residual of the Continuity Eqn. More than that it goes up and stays around 5e+01. I all ready tried changing the mesh(for a finer one) but it doesnt show any improvement . Thank you Felipe |
May 16, 2010, 18:39 |
#2 | |
aek
Rep Power: 16 |
hi felipb
i think u need to give more details for ur prb why u use the Kinetic Mechanism from Chemkin if u focus to simulate only the jet dynamycs ? i think also u dont need to make several changes in ur mesh if u say that they gave u a ggod convergence in ur first step Quote:
May 16, 2010, 19:05 |
Felipe B. Ch.
Rep Power: 16 |
I am using a chemkin kinetic mechanism because I want to later on simulate the ignition by activating the volumetric reactions, but first I wanted to check for the mixing process(profile), thats why right now I am simulating without reactions.
On the order side if I change the composition of the fuel inlet (hydrogen) to for example O2 or N2. The residuals start going down but very slowly, thats why I thought in making the mesh finer to maybe improve simulation of the diffusion process of H2 but I increase its density in almost factor 3 and I dont see any change. By the way im simulating 3D with symmetry boundaries in a quarter of a cylinder(just a quarter because the of the h2 injection position). |
May 18, 2010, 23:15 |
Mohammad Ghazvini
Rep Power: 16 |
I had the same problem with continuity. I played with the under-relaxation factors and it worked. decrease all the under relaxation factors to 0.2 for example. Try that and wait until it converges.
Mohammad |
May 19, 2010, 02:18 |
Felipe B. Ch.
Rep Power: 16 |
Thanks!!!! mahmohammad I am going to try that.
May 28, 2010, 19:43 |
it did work
Felipe B. Ch.
Rep Power: 16 |
For the people who saw my thread, is now solved:
I improved the mesh quality; in some areas the Aspect Ratio wasnt that good, (my geometry wasnt that simple). I increase a little bit the amount of cells close to injections points. I used the Pressure based solver with the coupled algorithm and I reduced the courant number to 40 at the beginning and later to 100 to increase the convergence speed. I also reduce the under-relaxation factors for the eqn of the species I was simulating from the default one to a value of 0.8 . The user manual of fluent does not recommend to use under-relaxation factors below 0.5. Thanks Mohammad for your help good luck to the others Felipe |
May 29, 2010, 14:19 |
Mohammad Ghazvini
Rep Power: 16 |
Felipe
I happy that your problem is solved. FYI, in some cases I had to start with underrelaxation factor of 0.01. You have to decrease it when there is sudden change in a variable. And is very common in reaction and species problems. Mohammad |
June 3, 2010, 11:19 |
Felipe B. Ch.
Rep Power: 16 |
Ok, I will take it in account, because reactions is my direction =) ... =S.
Thanks a lot again Felipe Bolanos |
April 12, 2016, 07:37 |
#9 |
Rep Power: 10 |
hi ...
would u plz help me? I want to simulate mixing of Two fluids. but by using species transport model, how can i allocate constant value to properties of each component? best regard |
July 21, 2016, 05:11 |
#10 | |
Narges
first using DEFINE/MATERIAL determine the properties of components, as usual. we simply do this at normal problems too. Then using CELL ZONE CONDITION/EDIT/MIXTURE SPECIES/ EDIT (in front of the material name: mixture template) you will choose your mixture component from the list. For determining the properties of mixture you will find it from the paper you work on it. Maybe it uses the averaging method defined in the help. or it can use one of the fluids , ... Calculate them or let the fluent calculate by itself. Check every part of HELP to clear for yourself. Good Luck Last edited by Narcis68; July 21, 2016 at 07:00. |
July 15, 2018, 07:45 |
#11 |
Rajan Bhandari
Rep Power: 8 |
I tried to decrease the under relaxation factor less than 0.5 and then run the simulation. But the continuity residual does not decreases instead makes a sine curve. Any recommendations?
first step in species transport without reaction | naus | FLUENT | 1 | April 12, 2016 07:35 |
Species transport | Eisa | FLUENT | 0 | May 17, 2006 04:40 |
Species transport eqn using UDS | Vishal | FLUENT | 0 | March 21, 2006 23:00 |
species transport equation | daniel | FLUENT | 0 | June 22, 2005 08:51 |
unsteady species transport | solomon | FLUENT | 0 | December 19, 2003 19:06 |
