May 30, 2010, 00:23 |
Help using DPM
Eric
I am using DPM to see how long does the 1000 massless particles take to travel across my mixing tank. I am using unsteady particle tracking and track with fluid flow time step. I inject particle once at time 0, and I set max. number of steps to a very large number since I don't know how long it takes the particle to escape. However, when I start the simulation, once the at the first time step all the particles left already. That doesn't make sense, unless the particles travel the entire tank in 0.05s. I expect it should be around 300s. Can someone give me some advice?
Thanks, Eric |
May 30, 2010, 12:42 |
ali
I think calculate particle lag time to have an idea of time
January 27, 2011, 11:27 |
#3 | |
I wonder if you have solved this problem. I run into the same problem now. Guangwei |
How to apply Transport Equation on DPM Scalars? | yuhai | FLUENT | 0 | May 19, 2010 10:38 |
DPM modeling | Mohsin | FLUENT | 0 | March 31, 2010 22:11 |
DPM - do the particles affect the liquid? | Nikhil Dani | FLUENT | 0 | January 1, 2009 11:58 |
slow after mesh for enhanced wall treat DPM | joshkemp | FLUENT | 0 | May 1, 2007 17:20 |
compatibity LES with DPM | Alex Munoz | FLUENT | 0 | March 26, 2003 21:13 |
