Flow around ship hull, multiphase setup!!
Like Tree3Likes
  • 3 Post By jack1980
Old   June 20, 2010, 17:45
Question Flow around ship hull, multiphase setup!!
Ali
alibul is on a distinguished road
Hi everyone,
I am trying to find the flow characteristics around a ship hull by using Fluent. I did the model, I did the meshing in Gambit everything is fine until so far. It is a multiphase problem (air and water), I have two velocity inlets, hence two continuum volumes, hence two interior boundary conditions etc. I have two pressure outlets (when I imported the meshing in fluent, it divided my outlet into two since there are two continuums).
However I am having some difficulties in setting the problem in fluent. First of all, I am trying to use the VOF model. When I have two continuum like this, how do I set up the problem? How do I define free surface in this case. My aim is to get the drag coefficient, surface elevation and wave profile on the hull. I searched every thread in these forums but I could not get a solid answer for my case.
Do I have to write a UDF for VOF or is there any other way to get the results by using two phases like how I have done? Or should I start the problem with one continuum in Gambit and one inlet and then introduce it in fluent as a multiphase model? If so, then how to do it?
I seriously need some help. Thank you very much in advance.
Ali
alibul is offline   Reply With Quote
Old   June 22, 2010, 16:58
Jouke de Baar
jack1980 is on a distinguished road
What you could do is:
- Have a split water velocity inlet and air velocity inlet. You can set the volume fraction of the water inlet to 1 in the boundary conditions panel
- For all other boundaries you will not have to make a distinction for the phase. This means you can have a single wall boundary and a single pressure outlet (with udf)
Have a look at pages 62 - 65 of https://docs.google.com/fileview?id=...MjNkZGJl&hl=en
Another option is open channel flow
s7evin, Dumith and zikrina like this.
jack1980 is offline   Reply With Quote
Old   June 23, 2010, 19:30
Ali
That was what I needed.. Thank you very much for the info and for the document..
Old   June 25, 2010, 09:23
Hermanus Henning
Hermanus Henning is on a distinguished road
Good day everyone,
I'm new to the CFD world and I would just like to say hi!
Alibul, thank you for posting the question, I'm in the same "boat".
Jack, thank you for the advice to Alibul, its very useful
Regards
Hermanus Henning is offline   Reply With Quote
Old   February 9, 2011, 06:00
Default ship
kabilan.B
kabilan is on a distinguished road
hai,
i want to know which multiphase is suitable for ship analysis.
when i solve by using vof, unstructure mesh, the error occurs i.e) over spills.
pls rply (vof or euler or mixture.....)
kabilan is offline   Reply With Quote
Old   February 9, 2011, 07:40
Default Vof
Hermanus Henning
Hello Kabilan,
I used the vof method because I'm moddeling a free surface and two immiscible fluids. What turbulence model are you using (if you are using ine at all)?
Regards
Old   February 10, 2011, 05:28
Default vof
kabilan.B
very thank you for reply,
i used k-e turbulence model............
Old   February 10, 2011, 08:43
Hermanus Henning
Pleasure,
I used the Transition SST model for my case...
Old   April 23, 2012, 05:51
rohit
harish123 is on a distinguished road
Originally Posted by jack1980 View Post
Dear Jacks,
Thanks for your reply on CFD online regarding VOF.
I have certain doubts like you said you have single outlet how it is possible bcz then udf will give different pressure for air outlet as air is having different density.
Also should we include wall adhesion and surface tension also.
Air should be compressible or incompressible.
If you can mail me on my mail id - rrmore@gmail.com i will verymuch thankful to you......
harish123 is offline   Reply With Quote
Old   November 30, 2012, 01:43
mehulkumar is on a distinguished road
I am trying to simulate flow around the ship hull using 2D, steady state, VOF simulation.
I have given air and water velocity as 1m/s, but due to some reason within 10 iterations velocity is going to high !!!
Can any buddy help in identify the reason for such a high velocity?
Thanks in advance.
Mehul
mehulkumar is offline   Reply With Quote
Old   September 20, 2013, 11:02
like.no.other
like.no.other is on a distinguished road
Hi guys
This is a good pdf for ship hull simulation
Heave and Pitch Simulation of Ship hull moving through head sea waves
enjoy!
www.CFDiran.ir
like.no.other is offline   Reply With Quote
Old   September 25, 2013, 03:50
Centurion2011's Avatar
Centurion2011 will become famous soon enough
Originally Posted by like.no.other View Post
Hi guys
enjoy!
what is the password for .rar files from http://www.cfdiran.ir/download/ ?
I'M NOT A GYNECOLOGIST BUT I'LL TAKE A LOOK.
Centurion2011 is offline   Reply With Quote
Old   September 4, 2015, 09:01
Lightbulb Collaborative project for multiphase flow around a boat hull
  #13
agakristo is on a distinguished road
if you are still interested in a simulation for a boat hull, then we started working on a collaborative project for a multiphase flow around a boat hull. We already have a group of people involved in it and the project is fully open to anyone additional who wants to join. We are posting all the results, images on the forum here:
https://forum.simscale.com/t/collabo...oat-hull/71/30
Would be great to have you join!
Cheers,
Agata
agakristo is offline   Reply With Quote
Old   September 8, 2016, 10:13
ANKUR GUPTA
ANKURIITD is on a distinguished road
Hey guys,
I have simulated the steady state free surface flow around a wigley hull using FLUENT.I am having problem in calculating the wave making drag and other post processing. Can anyone help me in the post processing the results???
I am getting the Cd value=5.84e-3
My wave profile is close to the experimental results....
Please help me in finding the other resistance parameters...
Thank you
ANKURIITD is offline   Reply With Quote
Old   November 7, 2017, 01:35
M. GOWTHAM
M. GOWTHAM is on a distinguished road
Hi Sir, my project is similar to yours I need some details about meshing, analysis , flow stimulation
If anybody have idea regarding Pls send the details to gowthamaero1117@gmail.com mail id
M. GOWTHAM is offline   Reply With Quote
Old   February 21, 2019, 02:50
Default How to view wave propagation
  #16
sriram
sriram9127 is on a distinguished road
It is a multiphase problem(air and water).
Initial velocity zero for both phase.
I want to run a simulation for 1m/s velocity of both phases and view wave pattern.
Please find the attachment. The residuals are converged, but I can't find the entire wave pattern. Give me some suggestions.
sriram9127 is offline   Reply With Quote
hull, multiphase modelling, vof model
Multiphase flow (Eulerian) modeling Umesh FLUENT 5 December 29, 2014 10:06
Ansys 11.0 CFX - solving electric potentials and multiphase flow cfd_multiphyiscs CFX 2 March 10, 2010 13:43
Solid-liquid flow (Eulerian-Eulerian multiphase model). panzer CFX 0 February 23, 2010 23:27
Multiphase flow problem icedou FLUENT 6 July 10, 2005 02:52
Multiphase flow with mass transfer? A. Ataki FLUENT 1 November 10, 2003 04:46
