FLUENT - EVAPORATION and CONDENSATION SIMULATION |
June 21, 2010, 08:44 |
Patryk
Rep Power: 17 |
Let's say there is a closed aluminum cube. The cube is filled in 1/5 with water and in 4/5 with air . The deck of the cube is a source of the heat. The surface of the cube is constantly cooled. The water in it evaporates, traveles to the surface, gets cooled, condensates and drops down (some kind of a heat pipe).
I want to simulate it with FLUENT. Questions: Which model of phases is appropriate(VOF,Eulerian,DPM,Mixture model)? How manage with mass transfer from liquid phase to gasous and vice versa? How simulate heat transfer in this case? Thank you in advance, Patryk |
April 24, 2014, 23:43 |
Xiaobing Zhang
Rep Power: 12 |
Hi I'm doing similar modeling, can u tell me how did you do this simulation in the end?: Thanks
April 25, 2014, 01:35 |
Junphy Liues
Rep Power: 12 |
I am working on this simulation right now, mixture is perfect I think, the result is better than other models. U need to wright some UDFs to realize the phase change.
April 30, 2014, 00:38 |
Xiaobing Zhang
Rep Power: 12 |
Hi Junphy,
Is it OK for you to share your UDF with me? I got stuck with condensation, and my results with evaporation is not that good. Can you please help me with this? My email is zhangxiaobinghust@gmail.com Thanks a lot! |
April 30, 2014, 02:29 |
Arun Tamilarasan
Rep Power: 12 |
Hey,
I am working on a similar problem but I am focusing on the evaporation behavior alone. The mixture model seems to work fine and as for the UDF, if you have the fluent UDF manual, you can refer it and get on it on your own. Also, you will have to patch water and vapor regions at t=0. For some reason, I cannot patch them and the vapor volume fraction seems zero always. Anyway, the mixture model will be the correct multiphase physics for your problem. Arun. |
May 14, 2014, 09:54 |
droplet evaporation
#6 | |
navid
Rep Power: 13 |
i'm working on evaporation of a single water droplet in a square computational field that is included static air. can u help me about settings of ansys fluent for this problem? any helps is appreciated. |
May 14, 2014, 11:07 |
Behrooz Jamshidi
Rep Power: 13 |
Hi
With AnsysFluent its not needed to write udf.It has the mass transfer equations for evaporation and condensation. These kinds of simulations are really hard to be handled by commercial codes. |
August 23, 2014, 21:14 |
Bill Wang
Rep Power: 11 |
Hi CFD-fellow,
I tried the evaporation and condensation mechanism of transient VOF model in FLUENT14.5, but the result is not good, as the phase fraction always change with time and in the final, either the liquid turned in to vapor or vapor turned into liquid. the problem is in the vapor domain, liquid shoud not exist vise verse. I did not interpret/compile any UDFs. At the initial of the simulation, I patched liquid in liquid domain and vapor in vapor domain. Have you worked the simulation out? Would you please give me some hint? email:1612955572@qq.com Thank you in advance. Regards, Bill |
February 20, 2016, 02:26 |
#9 | |
Nazim
Rep Power: 12 |
February 20, 2016, 02:27 |
#10 | |
Nazim
Rep Power: 12 |
February 20, 2016, 02:28 |
#11 | |
Nazim
Rep Power: 12 |
June 12, 2017, 14:22 |
#12 |
ram
Rep Power: 13 |
VOF is not suitable when phases are interpenetrating. Is is better to use it when boundary between phases is sharp as like open channels (water - air)
As far as in know, older versions of Fluent dont have phase change icon. it is better to use Ansys Fluent versions. |
July 4, 2017, 01:51 |
#13 |
Hi all
Firstly, from my experience vof model is the best and the easiest way to deal with evaporation- condensation multiphase problem. Secondly, do you have any update on your simulation? Regards Sent from my SM-G900I using CFD Online Forum mobile app |
September 25, 2018, 14:17 |
#14 | |
Tonoy Mondol
Rep Power: 7 |
January 15, 2019, 06:50 |
#15 | |
GW
Rep Power: 7 |
March 12, 2019, 08:09 |
#16 | |
jeet verma
Rep Power: 7 |
June 20, 2019, 20:28 |
#17 |
Soumitra Vadnerkar
Rep Power: 7 |
I am using evaporation-condensation model. I also tried the Mass rate Linearization UDF available in Fluent UDF guide. But I am not able to see the considerable liquid vapor fraction.
My case is tube flow inlet at 240C @ 3 MPa water vapor. Tube wall is isothermal @100C. At exit pressure drop is 7.25KPa (experiment) with complete condensation to liquid phase. I am getting the pressure drop right, but temperature profile significantly lower than the experimental. Can somebody suggest me something on this. my email is soumitra2102@gmil.com Thank You. |
September 27, 2020, 09:22 |
#18 |
Aman Jaiswal
Rep Power: 5 |
hello sir, can you please help me simulating a single water droplet evaporation in static air surrounding.
my mail : aman.mec1721@yahoo.com |
September 27, 2020, 09:23 |
#19 | |
Aman Jaiswal
Rep Power: 5 |
evaporation condensation |
Can Fluent perform evaporation and condensation simulation? | Wei Shao | FLUENT | 25 | December 1, 2017 04:12 |
Water Evaporation and condensation modeling | Linjie | FLUENT | 3 | February 6, 2012 13:08 |
Evaporation and condensation in a tube | Wei Shao | Main CFD Forum | 4 | September 16, 2009 10:19 |
Water Evaporation and condensation modeling | Linjie | CFX | 6 | May 24, 2007 14:55 |
condensation in FLUENT | juraj | FLUENT | 0 | December 14, 2004 06:53 |
