How can I convert GUI journal to TUI journal
Like Tree1Likes
  • 1 Post By Zaktatir
Old   July 5, 2010, 07:10
Default How can I convert GUI journal to TUI journal
Harry
harry is on a distinguished road
Hi All,
Through fluent windows interface, I can readily record a GUI journal. How can convert this journal to TUI journal that required in a batch simulation in linux?
I would appreciate your suggestions.
Best regards,
Harry
harry is offline   Reply With Quote
Old   July 5, 2010, 10:31
Harry
Or how can I utilize windows to setup fluent case file on linux
Old   July 6, 2010, 02:14
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you can create a journal file from Fluent:
before setting your case, go to file/write/start journal...
Then set up your case, once you are finished, go to file/write/stop journal...
Fluent should write everything you did in a journal file, which you can now read...
hope it helps
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 6, 2010, 02:18
Harry
I can only use TUI model in linux. So a GUI journal is not working.
Old   December 4, 2013, 13:48
magicalmarshmallow is on a distinguished road
BUMP!
I'm having the same problem. I need to generate some results pretty quick. I've only 2 cases to run, but they're too big for my local computer so I have to use a Linux HPC cluster in Batch mode.
Creating a GUI journal file is easy - File>Write>Start Journal......."set boundary conditons etc etc"....File>Write>Stop Journal
Does anyone know how to turn this GUI journal file into one which can be used in the TUI?
magicalmarshmallow is offline   Reply With Quote
Old   December 4, 2013, 14:02
Zaktatir is on a distinguished road
check the cx commands and try to translate manually to native TUI commands
Zaktatir is offline   Reply With Quote
Old   December 4, 2013, 15:50
If I set FLUENT up and Initialise the solution using the GUI, then save the case and data. Can I then, in my journal file, just read in the case and data and solve? Do I need to set materials and boundary conditions, add materials etc using the TUI?
Old   December 4, 2013, 16:28
1-yes.
2-No.
From self trying one learn much faster..
bikooo3878 likes this.
TUI Commands from GUI? Carlos FLUENT 6 May 22, 2013 18:05
journal not work without GUI? sophie FLUENT 20 October 17, 2006 03:32
combine Scheme and TUI possible in Fluent Journal? Qian Zhen FLUENT 0 November 11, 2005 22:54
help needed about phase change Yanhu Guo Main CFD Forum 4 January 23, 2001 23:16
