July 25, 2010, 14:07 |
Pressure & Temperature dependent EOS
henry clarke
Does anyone whether it is possible to create or link a pressure and temperature dependent equation of state, i.e. p=f(rho,T) in fluent? I am trying to model a multiphase cryogenic flow so both temperature and pressure have a large enough effect that they must be considered. Most of the documentation I have read so far talks about defining density as a function of either temperature or pressure...
Thanks |
October 31, 2011, 17:55 |
navid
have you solved your problem? Because I have the same problem. I need to implement an EOS of water that p=p(rho,t). Do you know how is it possible? Can I set a table of these parameters in fluent or i should write a UDF. |
eos, udf density |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Instantaneous pressure and temperature | George Thomas | CFX | 1 | August 20, 2008 04:47 |
FIDAP and temperature dependent mat properties | semetay | FLUENT | 0 | July 11, 2006 13:45 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
