Pulsatile pressure inlet with pressure outlet
Old   August 10, 2010, 07:14
Post Pulsatile pressure inlet with pressure outlet
adrian lynch
a.lynchy is on a distinguished road
Hi everyone
I am trying to model blood flow in an artery. To do this I want to specify a pulsatile pressure inlet using a UDF and find the resulting pressure at the outlet from the pressure that is dropped through the system.
However when I use a pulsatile pressure inlet with a pressure outlet, I am required to set a value for pressure at the outlet (this outlet pressure I don’t want to set, I want to determine this). Fluent takes the pressure value at the outlet as a constant and adjusts the pressure inlet depending on the pressure loss in the system. Therefore I end up with a pulsatile pressure inlet and steady pressure outlet.
I realise this is to do with the way the Fluent solver works but is there any way I can specify the pulsatile pressure inlet I require and have fluent determine the transient pressure outlet ? Is this the best way to go about modelling blood flow when using pressure BC’s?
Many Thanks
a.lynchy is offline   Reply With Quote
Old   March 22, 2012, 10:41
kamar
amoon is on a distinguished road
Originally Posted by a.lynchy View Post
Hi everyone
Many Thanks
Dear all,
I am using Ansys to simulate how sinusoidal pressure at the inlet of a tube propagates and arrives to the output.
I am going to record the pressure at both inlet and outlet on the same time.
Please can anyone tell me how i can do that.
many thanks
amoon
amoon is offline   Reply With Quote
Old   March 22, 2012, 11:02
Domenico
doronzo is on a distinguished road
hi
please anybody corrects me if i'm wrong, but what i know is that pressure outlet refers to eventual backflows, and not to the main flow, so the obtained outlet pressures are a simulation result, whereas the input value to the pressure outlet panel is to be referred to the backflows, if there are.
also, introducing a pressure value in the operating conditions panel allows not to introduce any pressure at the outlet
regards
doronzo is offline   Reply With Quote
Old   March 23, 2012, 13:45
Nik
nikhil is on a distinguished road
Do you have the mass flow rate information through the domain?
If you have, then what you can do is treat your outlet as "Mass flow inlet". Provide negative values of mass flow rate at this boundary ( doing so you will drive the flow out of the domain). And you will be able to find the resulting pressure at the outlet boundary
nikhil is offline   Reply With Quote
pressure bc, pressure outlet, pulsatile
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 02:10
velocity inlet and pressure outlet Ebrahim FLUENT 5 January 15, 2015 17:14
Pressure Inlet Velocity prapanj OpenFOAM 11 June 23, 2009 11:15
Pressure Rise Error emueller CFX 0 May 5, 2009 11:08
Pressure Inlet BC Prasad FLUENT 3 January 4, 2009 22:55
