Water-Air Separation inside cyclonic separator |
August 11, 2010, 02:16 |
Sandy
I am trying to simulate a cyclonic separator using fluent. There is one inlet and two outlets. At inlet water-air mixture is entering the system. Let me give some name to two outlets, namely top outlet and bottom outlet. Top outlet is exposed to atmoshphere where as bottom outlet is having pressure of 30 psia. Currently i am using mixture model without slip velocity and results are like large amount of air is gonig through bottom outlet, where as test shows that large amount of air should go from top outlet. It means CFD is not able to capture the separation of air from water inside separator. Is there any problem my CFD set up in fluent? |
air separation |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
Separation phenomenon of water, droplet and air | Raymond | CFX | 0 | July 9, 2004 22:59 |
Help!!!problems in air jet into water bath | kim | FLUENT | 4 | June 9, 2003 07:04 |
meshing F1 front wing | Steve | FLUENT | 0 | April 17, 2003 12:37 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
