Volume Fraction & Velocity Magnitude
Old   September 3, 2010, 10:32
Default Volume Fraction & Velocity Magnitude
alven
alven299 is on a distinguished road
Greeting to all CFD users,
I'm simulating a 3D system using FLUENT and currently facing problem in extracting certain data from it. Given the following:
Volume: 0.1 m3
max velocity magnitude: 1.7 m/s
Question:
How can I ask FLUENT to generate the percentage of volume which has velocity magnitude of less than 5% of the maximum velocity?
Thank you very much in advance for any suggestions and inputs.
alven..
alven299 is offline   Reply With Quote
Old   September 4, 2010, 02:30
alven
I have managed to figure it out. First...use the iso-value adaptation to mark the region of desired velocity magnitude. Then separate the marked zone in grid>separate>cells. Finally, use the report volume and select the newly separated zone.
alven
Errno 24 linux ivanwhlau OpenFOAM Running, Solving & CFD 6 July 1, 2009 10:16
interDyMFoam - change in volume fraction gopala OpenFOAM Running, Solving & CFD 0 April 27, 2009 10:46
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 11:16
How to set volume fraction in two phase flow Kamel FLUENT 2 March 23, 2007 00:06
the Eulerian model and the lower volume fraction hx li FLUENT 2 October 27, 2005 06:17
