MPI problem with fluent
Like Tree1Likes
  • 1 Post By kondora
Old   October 15, 2010, 01:32
Default MPI problem with fluent
aryanet
aryanet is on a distinguished road
Hi there,
I am new to run fluent in linux centOS. I have installed fluent 6.3 on three machines. but when I run the command below:
/data/Fluent.Inc/bin/fluent -g 3d -cnf=/root/host -t4
It ends up with the following output:
[root@MDS1 ~]# /data/Fluent.Inc/bin/fluent -g 3d -cnf=/root/host -t4
/data/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 -g 3d -cnf=/root/host -t4
/data/Fluent.Inc/fluent6.3.26/cortex/lnamd64/cortex.3.7.3 -f fluent -g (fluent "3d -pethernet  -host -r6.3.26 -t4 -mpi=hp -cnf=/root/host -path/data/Fluent.Inc")
Loading "/data/Fluent.Inc/fluent6.3.26/lib/fluent.dmp.114-64"
Done.
/data/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 3d -pethernet -host -t4 -mpi=hp -cnf=/root/host -path/data/Fluent.Inc -cx MDS1:47715:35420
Starting /data/Fluent.Inc/fluent6.3.26/lnamd64/3d_host/fluent.6.3.26 host -cx MDS1:47715:35420 "(list (rpsetvar (QUOTE parallel/function) "fluent 3d -node -r6.3.26 -t4 -pethernet -mpi=hp -cnf=/root/host ") (rpsetvar (QUOTE parallel/rhost) "") (rpsetvar (QUOTE parallel/ruser) "") (rpsetvar (QUOTE parallel/nprocs_string) "4") (rpsetvar (QUOTE parallel/auto-spawn?) #t) (rpsetvar (QUOTE parallel/trace-level) 0) (rpsetvar (QUOTE parallel/remote-shell) 0) (rpsetvar (QUOTE parallel/path) "/data/Fluent.Inc") (rpsetvar (QUOTE parallel/hostsfile) "/root/host") )"
     Welcome to Fluent 6.3.26
     Copyright 2006 Fluent Inc.
     All Rights Reserved
Loading "/data/Fluent.Inc/fluent6.3.26/lib/flprim.dmp.1119-64"
Done.
Host spawning Node 0 on machine "MDS1" (unix).
/data/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 3d -node -t4 -pethernet -mpi=hp -cnf=/root/host -mport 127.0.0.1:127.0.0.1:45271:0
Starting /data/Fluent.Inc/fluent6.3.26/multiport/mpi/lnamd64/hp/bin/mpirun -TCP -f /tmp/fluent-appfile.16803
mpirun: No route to host
mpirun: Bad file descriptor
I don't know what is wrong with hpmpi!?
aryanet is offline   Reply With Quote
Old   October 22, 2010, 16:02
Basharat
elbasharat is on a distinguished road
the error is not with your mpi but with the parallel connectivity. check your ssh or rsh then run it again and make sure to stop the firewall. tell me then if you get any error again.
Rgds
Martin
elbasharat is offline   Reply With Quote
Old   October 23, 2010, 16:39
Unhappy
aryanet
Wooow! thanx, It was a problem with the firewall. But after solving that another problem comes up:
[root@MDS1 bin]# /data/Fluent.Inc/bin/fluent -g 3d -cnf=/root/host -t2
/data/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 -g 3d -cnf=/root/host -t2
/data/Fluent.Inc/fluent6.3.26/cortex/lnamd64/cortex.3.7.3 -f fluent -g (fluent "3d -pethernet  -host -r6.3.26 -t2 -mpi=hp -cnf=/root/host -path/data/Fluent.Inc")
Done.
/data/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 3d -pethernet -host -t2 -mpi=hp -cnf=/root/host -path/data/Fluent.Inc -cx MDS1:44145:40097
Starting /data/Fluent.Inc/fluent6.3.26/lnamd64/3d_host/fluent.6.3.26 host -cx MDS1:44145:40097 "(list (rpsetvar (QUOTE parallel/function) "fluent 3d -node -r6.3.26 -t2 -pethernet -mpi=hp -cnf=/root/host ") (rpsetvar (QUOTE parallel/rhost) "") (rpsetvar (QUOTE parallel/ruser) "") (rpsetvar (QUOTE parallel/nprocs_string) "2") (rpsetvar (QUOTE parallel/auto-spawn?) #t) (rpsetvar (QUOTE parallel/trace-level) 0) (rpsetvar (QUOTE parallel/remote-shell) 0) (rpsetvar (QUOTE parallel/path) "/data/Fluent.Inc") (rpsetvar (QUOTE parallel/hostsfile) "/root/host") )"
     All Rights Reserved
Done.
/data/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26 3d -node -t2 -pethernet -mpi=hp -cnf=/root/host -mport 127.0.0.1:127.0.0.1:37906:0
Starting /data/Fluent.Inc/fluent6.3.26/multiport/mpi/lnamd64/hp/bin/mpirun -TCP -f /tmp/fluent-appfile.16143
HP-MPI licensed for execution of Fluent.
0: mpt_connect: error: connect failed: Connection refused
0: mpt_establish_connection: error: unable to connect: Illegal seek
0: mpt_connect_to_server: error: cannot establish connection; bye.: Illegal seek
MPI Application rank 0 exited before MPI_Finalize() with status 0
By the way, I have installed fluent on both machines!
Would you help plz?
Old   October 24, 2010, 01:45
Basharat
ok ..
you must check your proper connectivity there not dynamics IP but static.
then if you know about ssh configuration then do it for the parallel computing.
I suggest you to use the -ssh in your command to run fluent. and also do the permissive of SElinux also. sometimes it also stops the suspicious connectivity. anyways do the following and let me know.
cheers
Rgds
Martin
Old   October 24, 2010, 01:57
aryanet
ok ..
cheers
Well, I have set all the IP addresses manually and there is no dynamic IP address.
I ran the fluent with -ssh switch, but nothing happened new.
SElinux is completely disabled also.
I've really get stuck...
Old   October 24, 2010, 05:40
Basharat
ok then check whether your fluent is installed proper i mean there sometimes mpi folder doesnt exist.
I didnt experience that kind of error before.
there must be some human error.
Rgds
Martin
Old   October 24, 2010, 14:37
Grzegorz Kondora
kondora is on a distinguished road
Check if MPI is correctly installed. Run FLUENT with -ssh option. Before that do: cd ~; cd .ssh;
ssh-keygen -dsa; {blank passphare - ENTER, ENTER}; cat id_dsa.pub > authorized_keys2; ssh 127.0.0.1; {confirm with yes}; ssh 127.0.1.1; {confirm with yes}; check if you can ssh to 127.0.0.1 and 127.0.1.1 without typing a password. Generally: google -> "ssh without password".
Try: fluent 2d -ssh -mpi=intel when MPI is not working. Hope I helped.
anijg05 likes this.
kondora is offline   Reply With Quote
Old   October 24, 2010, 14:45
Grzegorz Kondora
Sorry, i didn't read that you are using different machines, so instead of doing ssh without password to localhost, try this: http://linuxproblem.org/art_9.html
Old   October 24, 2010, 15:13
aryanet
Well, I'm sure ssh has configured properly.
But, thanx from your helps.
Old   December 23, 2015, 12:35
mohammad
mmkkeshavarzi is on a distinguished road
Hi
since i am new in Linux,Ubuntu i have some sort of same problem
I try to open Fluent on my device, but i encounter with this error:
999999: mpt_get_dot_address: warning : UNI - SERVER _ > 127.0.0.1 check your system network configuration!
starting / user/ansys_inc/v150/fluent/fluent15.0.0/(.....), mpirun: rsh: command not found
if anyone can help me to get through this problem i would really appreciate it
thanks in advance
mmkkeshavarzi is offline   Reply With Quote
Old   February 6, 2016, 09:53
Post
  #11
vlg
villager is on a distinguished road
Your problem is possibly solved by adding
-ssh
switch to the start command/script:
fluent -ssh ....
If you really want rsh you should have it installed!
which rsh
should find it. But note, that it is often symlink to ssh. Do not know, if this strange config would work with FLUENT.
Using rsh on Ubuntu:
on each computing node:
sudo apt-get install rsh-server
sudo apt-get install rsh-client
and on the submit node (if differs from computing node)
Originally Posted by mmkkeshavarzi View Post
Hi
thanks in advance
villager is offline   Reply With Quote
Old   February 6, 2016, 10:05
Post
  #12
vlg
1) The first thing to try is to run without cnf option.
FLUENT would not make him wait to spawn so much process on your current machine, that you specify with -t option:
 /data/Fluent.Inc/bin/fluent -g 3d -t2
2) The second thing to try is to login to target machines. I suggest using ssh.
E.g., your machines are machine1 and machine2.
ssh machine1
(should give you shell on this machine without(!!!) any confirmation - i.e., without password, yes/no and soon)
ssh machine2
(too)
Run via ssh with explicit node list (for example, we would require two processes on each machine):
 /data/Fluent.Inc/bin/fluent -g 3d -t2 -ssh -cnf=machine1:2,machine2:2
3) The third thing is to use file like you did with "-ssh" option.
You could change ssh to rsh everywhere, though. I didn't use it, but I think the workaround is almost the same.
Cheers, John.
Done.
     All Rights Reserved
Done.
Would you help plz?
Old   February 7, 2016, 06:29
mohammad
Thank you Villager, my problem solved
-ssh
fluent -ssh ....
which rsh
Old   June 21, 2016, 10:46
Khunnie_baby is on a distinguished road
hello, i'm now having the same problem with u, how did u solve your problem? Would u plz help me? thank u very much!
Khunnie_baby is offline   Reply With Quote
Old   June 21, 2016, 10:47
Old   June 21, 2016, 22:02
hi,i have the same problem with parallel connective, so i checked the ssh and rsh and stopped the firewall, but the problem are still exist. would you please help me to solve this problem?
Old   January 5, 2017, 06:33
Default check your hosts file
  #17
lv
lv4662 is on a distinguished road
the real public IP address + your hostname must be in the hosts file, which is in the folder /etc
Hi
thanks in advance
lv4662 is offline   Reply With Quote
Old   October 30, 2017, 21:04
lv
in ubuntu16.04, 127.0.1.1 + hostname is the default form in the hosts file
Problem running Fluent on amd64 Manfred FLUENT 10 March 23, 2013 06:47
Problem running fluent with InfiniBand blackpuma FLUENT 10 August 28, 2011 01:16
Fluent boundary conditions problem bobo FLUENT 2 July 3, 2009 06:28
Problem in running fluent 6.3 (64 bit) on ubuntu 8.1 (64 bit) Mir5 FLUENT 3 April 29, 2009 10:32
Problem using parallel Fluent Gustavo FLUENT 0 June 27, 2004 23:12
