meshing and boundary condition
Old   October 28, 2010, 09:57
Default meshing and boundary condition
no183
no183 is on a distinguished road
As the picture show, the computer casing is mesh on the component (motherboard, HDD, etc) but this is not i want as i want to know the heat flow profile that inside the casing, which is the area not been mesh, so how do i done that?
and what is the boundary condition i can set?
no183 is offline   Reply With Quote
Old   October 29, 2010, 01:03
-mAx-'s Avatar
Maxime Perelli
you are meshing the outer surfaces of components, which is correct since they are surface limits of your domain
Just check if you can select components as volume. If yes, then you need to delete them, as far as you don't want to compute any solid conduction.
Old   October 29, 2010, 05:52
no183
can, but it select the whole casing, i cant choose anything..
Old   October 29, 2010, 05:58
-mAx-'s Avatar
Maxime Perelli
so you only have one volume, and components surfaces are part of the volume, right?
It means your components are empty and only their outer surfaces will be meshed.
So that is correct.
You try to compute heat transfer in the domain defined between the casing and components (boolean substract between whole casing and components results in what you actually have)
Old   January 5, 2011, 02:32
no183
sorry, away from online since holiday..
Now, i still cant get what u mean, is it anyone here can assist me on that? give me a step by step tutorial
Old   January 5, 2011, 02:35
no183
btw, any tutorial for fluent and gambit?
Old   January 5, 2011, 03:26
-mAx-'s Avatar
Maxime Perelli
provide me your .dbs file
Old   January 5, 2011, 06:45
no183
how? email?
Old   January 5, 2011, 06:47
no183
i save it in stp file
Old   January 5, 2011, 07:24
-mAx-'s Avatar
Maxime Perelli
send the dbs file (save your session in Gambit).
In this way I can observe errors you can have.
Upload the file on a share server like rapidshare or whatever
Old   January 5, 2011, 09:00
no183
http://rapidshare.com/files/440932754/test.zip
here it is..
kindly state what u have done, i mean how u done it, as i am still a learner. thanks
Old   January 6, 2011, 01:20
-mAx-'s Avatar
Maxime Perelli
As I thought, you only have solid elements.
Since you want to compute heat exchange, you don't need solid elements, but the air volume contained in your model.
If you enable shaded mode (render icone) you will see that your box isn't close at the top (cf picture)
So I would create a surrounding volume (englobing all your solid elements) and substract this closed box with all your solid elements.
Create a surface by sweeping edge 2112 with vector (0 -440 0)
Create a volume by sweeping created face with vector (0 0 -190.5)
That will be your surrounding volume.
Finally substract all your solid elements from this volume. The result will 2 volumes, with one small you need to delete
If you look at the bottom (shaded mode on) you will see that you don't have the solid elements anymore, but only their outter surfaces.
Tha'ts what you need.
Old   January 6, 2011, 08:09
no183
bro, i manage to do the first 2 step.. but the third step how? frankly, i am idiot in FLUENT, as this model i drawn from solidwork, this is my first time using FLUENT, forgive my weakness.
Old   January 6, 2011, 08:38
-mAx-'s Avatar
Maxime Perelli
volume/substract
right-click on the icon (actually the unite icon is displayed)
Old   January 6, 2011, 08:44
no183
ya, i get that, but which subtract to which.
Old   January 6, 2011, 08:50
-mAx-'s Avatar
Maxime Perelli
*biggest volume as first entry
a*ll other (solid parts) as second entry (understand you can select multiple volumes)
Old   January 6, 2011, 08:56
no183
hmm, what is the biggest volume btw, there are few volume that can be selected at the casing..
Old   January 6, 2011, 09:00
-mAx-'s Avatar
Maxime Perelli
the biggest volume, is the one you just created (the one generated with your 2 succesfully steps)
In other words: none of your imported (solid) parts
Old   January 6, 2011, 09:03
no183
so is the last volume created, in other word, the largest number?
Old   January 6, 2011, 09:11
-mAx-'s Avatar
Maxime Perelli
independantly from your volume id, select the volume surrounding the others.
It will be red displayed. If it is not the volume you want, click on the middle clik of your mouse, it will select another, etc...
Once you selected the right one, check its name in the pick-box
Else you open the journal file or the transcript file (or navigate in the transcript window) and check the id given to the volume after the sweep face operation.
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 00:35
Boundary layer meshing problem in Gambit Crystal FLUENT 0 June 12, 2009 20:58
GAMBIT problem with 3D Boundary Layer when meshing Anthony Haroutunian FLUENT 2 March 26, 2008 02:02
Help Urgent about changing boundary condition Anjum Naveed FLUENT 7 August 14, 2006 12:25
Boundary Layer Meshing of a nosecone Chris FLUENT 1 March 15, 2005 12:42
