Processor affinity not being set
Old   November 1, 2010, 12:44
Default Processor affinity not being set
vulcan is on a distinguished road
I am trying to use a 12 core (6 Hyperthreaded) and when running
fluent 2ddp -t12
I am getting the following error/warning
Process affinity not being set. core ids failed check (maxid>cores, ht>1)
Does anybody have any idea what it means? The simulation starts but I am getting this warning.
Thanks
vulcan is offline   Reply With Quote
Old   November 3, 2010, 09:34
Default Try with lesser
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Try with lesser number. And when you say 6 hyperthreaded, it might mean that there are 6 dual core processors.
If you have unix machine, check using cat /proc/cpuinfo in a terminal, what is the last number of processor. If it is 11, then your command is perfectly alright. However, if it shows some other number, say n, then your command can be fluent 2ddp -tn+1
vinerm is offline   Reply With Quote
Old   April 12, 2015, 01:58
justgoon
yilufeihua is on a distinguished road
When I started fluent to read file,I got the following error/warning
Note:Rank=0:Process affinity not being set. Offsets failed sanity check.
Note:Rank=1:Process affinity not being set. Offsets failed sanity check.
Note:Rank=2:Process affinity not being set. Offsets failed sanity check.
(My workstationo has 12 core, even I use 2 core ,I'll also receive this message)
How can you solve the problem?
yilufeihua is offline   Reply With Quote
Old   June 18, 2016, 09:03
sunilpatil's Avatar
sunil
sunilpatil is on a distinguished road
Have you solved this problem
sunilpatil is offline   Reply With Quote
Old   June 18, 2016, 09:11
Default Not an error
vinerm's Avatar
Vinerm
This is not an error or even a warning. This is just an information to tell user that the processor is already in use by other programs. If you make sure that no other program is using these cores then you'll observe that Fluent gives no such warning or information.
Old   June 18, 2016, 09:57
sunilpatil's Avatar
sunil
Thank you for your reply. Recently I have posted a question (http://www.cfd-online.com/Forums/flu...rocessing.html) do you know how to solve this parallel processing problem.
Old   March 22, 2022, 08:01
Default MPI type
Y.C. Zhang
idfccc is on a distinguished road
If your CPU is AMD's product, you can have a try to set the MPI types to "msmpi". I used this mothed, then the time cost of my simulation is decreased obviously.
idfccc is offline   Reply With Quote
Old   July 6, 2022, 07:31
wind
waynetsu is on a distinguished road
My CPU is Intel. I also feel my parallel simulation is much more time-consuming than before. Does this "msmpi" connected to the CPU type?
waynetsu is offline   Reply With Quote
Old   October 26, 2023, 02:03
@Arash is on a distinguished road
Hi Dear friend,
I use an Intel processor that has 24 physical cores. When I use the number of cores for example 14 or 16 or... in order to parallelize and reduce the solution time, my solution goes slowly. What should I do ?
Thankyou
@Arash is offline   Reply With Quote
Old   October 26, 2023, 02:05
Hi Dear friend,
I have exactly the same problem as you and my processor is Intel.
Did you manage to fix this problem and use more cores for parallelization?
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
Porous region set braket FLUENT 4 November 18, 2010 02:09
What value shall I set for the Convergence criteria? steventay CFX 7 May 14, 2010 12:44
Install problem in linux navaladi OpenFOAM Installation 11 July 17, 2008 02:24
Ibm java gcc rrr OpenFOAM Installation 2 December 30, 2005 04:18
