December 13, 2010, 00:07 |
gambit edge node spacing
Md. Sayeemuzzaman
Rep Power: 16 |
i want to have a fixed number of nodes on a edge but i want then with a specified initial spacing along with a increment so that the mesh is fine to coarse. can someone help how to execute that in gambit.
i was trying to use the grading and spacing option in MESH EDGE section of GAMBIT |
December 13, 2010, 02:54 |
Maxime Perelli
Rep Power: 41 |
in Grading specify the right type: successive ratio is choosen as default, try exponent and move the slide-bar
In memory of my friend Hervé: CFD engineer & freerider |
December 13, 2010, 05:12 |
Md. Sayeemuzzaman
Rep Power: 16 |
thanks mAx .... i tried that but i haven't been able to figure out which type i want to use and why.....i guess i have to try that out on my own.
gambit 2.4.6, mesh control, node spacing |
Gridgen node spacing | Vincent | Pointwise & Gridgen | 4 | August 7, 2016 17:33 |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Gambit face meshing with a common edge | stella | FLUENT | 1 | October 28, 2005 05:09 |
small node spacing | Gary Holland | FLUENT | 13 | June 10, 2005 10:06 |
