flow in a vertical annulus
Old   December 14, 2010, 02:01
Default flow in a vertical annulus
Arun
ramcharan is on a distinguished road
hi,, i am modelling a flow in vertical annulus with porous media, with centrally placed heater and flow inlet and outlet conditions. it is surrounded by insulation. boundary conditions given are velocity inlet , volumetric heat generation and out flow. i am getting a reversed flow and there is no temperature rise in the annulus.
help me.....
ramcharan is offline   Reply With Quote
Old   December 14, 2010, 02:15
bunny
bunny is on a distinguished road
hi.... i am also dealing with the same kind of problem. i have problem with out flow condition. i extended the domain and imposing new conditions....
bunny is offline   Reply With Quote
Old   December 16, 2010, 01:35
bunny
i tried it n i didnt got the answer.....can any body help us
Old   December 16, 2010, 11:15
Default reversed flow
Rashmichem is on a distinguished road
hi
Check your operationg conditions..(Gravity) and try changing BC for velocity use direction and magnitude option.
good luck
Rashmichem is offline   Reply With Quote
Old   December 22, 2010, 01:48
bunny
i gave velocity inlet and outflow condition, volumetric heat generation from heater and remaining side adiabatic.. i am using boussinesq approximation....
Old   December 22, 2010, 03:14
Change your outlet BC to outflow. and let us know about your results.
Old   December 23, 2010, 06:27
bunny
if i use air instead of water ..temperatures r rising upto 100 deg. for water its not lik that. volumetric heat generation is 300000 w/m^3.
also pls tell me how to model a porous medium....
Reversed flow in Vertical axis wind turbine Anonymized_JL1 FLUENT 2 April 11, 2012 03:13
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
Free convection flow over vertical flat plate Polly Main CFD Forum 1 February 11, 2003 13:25
Free convection flow over vertical flat plate Polly CFX 0 February 11, 2003 02:51
vertical pipe flow sanjib das sharma CFX 2 July 30, 2001 06:17
