Heat Exchanger Model
Old   December 27, 2010, 15:34
Default Heat Exchanger Model
Anonymous
sak2129 is on a distinguished road
To anyone who can help:
I searched this form for issues similar to the one I am facing, but wasn't able to find a solution.
I am modeling a tube bank using the heat exchanger model and porous media. Basically, I have defined a mass flow inlet at a square boundary. The primary fluid travels in a rectangular duct and eventually hits the heat exchanger where it loses some energy to the auxiliary fluid. The auxiliary fluid is specified with just one pass, going from the bottom of the duct to the top.
I am using the heat rejection option with the NTU method. Here are the findings from what I have done so far:
1) The pressure drop in the air heater is as expected
2) The heat rejected from the primary fluid is as specified
3) The auxiliary fluid inlet temperature (computed by Fluent) is unreasonable (negative at times)
4) When I print the heat exchanger report, Fluent keeps printing the constant specific heat for the auxiliary fluid even if I read an UDF for enthalpy.
My questions are as follows:
1) If I am getting unreasonable values for the auxiliary fluid temperature, how do I fix my solution to ensure my primary fluid side calculations are correct?
2) Is there a special way to make Fluent use the UDF that you specify under the auxiliary fluid tab? Also, is there a way of verifying that Fluent actually used your UDF instead of taking constant specific heat for the calculations?
If anyone can assist, it'd be much appreciated. Thank you!
sak2129 is offline   Reply With Quote
Old   December 30, 2010, 19:40
zhll
lucio is on a distinguished road
the UDF for auxiliary fluid can only be used in the simple-effectiveness-model !so you couldn't use it in the NTU model.
lucio is offline   Reply With Quote
Old   December 8, 2014, 07:28
Default Query
Tushar
tushar.apatil is on a distinguished road
How do we calculate no. of passes/rows & /columns for a given model in NTU method, in fluent??
tushar.apatil is offline   Reply With Quote
Old   September 26, 2017, 01:29
ashish garg
ashish garg is on a distinguished road
I am trying to analysis a fin tube radiator by using heat exchanger model in fluent... is there any tutorial or video that state from beginning of geometry to meshing to using of this heat exchanger model.. please provide me the link..
thanks
ashish garg is offline   Reply With Quote
convection, fluent, heat exchanger, heat exchanger model, udf
Integration of a Custom C++ Model into FLUENT Syed Haider FLUENT 2 March 6, 2018 23:37
Heat Exchanger Model - urgent JSM FLUENT 6 September 22, 2007 04:25
Heat Exchanger...TWO Walid CFX 2 July 11, 2005 19:04
BIG TROUBLE with heat exchanger and porous media!! Andrea FLUENT 0 February 20, 2005 07:49
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
