Setting Reynolds number in Fluent for plunging airfoil |
TWB
Rep Power: 19 ![]() |
I have problems setting the correct Re no. for my simulation. I want to simulate a plunging airfoil at Re=10000. Since viscosity of air = 1.7894e-5, density of air=1.225, Re = u_inf*density*length/viscosity. So to get Re=10000, I set u_inf=0.17894 m/s I also set the reference value under the report menu. My airfoil length is about 1m, which is the reference length. Is this correct? Did I miss out anything? My answer is different from some published results. |
Actually flow is define by Re,Mach and alpha. normally we have certain range of alpha so it is known.
Re and mach number set in fluent must match the Re and mach of the experimenta/published results. 1st case Mach and chord length is given. then you have to adjust the viscosity to match the required reynolds number 2nd case for the given reynold number find the density and viscosity from altitude charts and then put these values in reynolds relation to find chord.put this chord in reference values.obviously mach number will be given to you.so you have to change mach in to velocity by multiplying it with acoustic speed corresponding to given reynolds number. Try it and let me know what happens? fahemsagi@yahoo.com |
Shuvam Mohanty
Rep Power: 6 ![]() |
I am working on a hydrocyclone and want to calculate the Reynolds number after completion of the simulation. Can anyone please help me how to find that in postprocessing?
reynolds number averaging?? | qrie | Main CFD Forum | 0 | June 26, 2010 03:46 |
What is "Resolved Reynolds Stress" for LES model in Fluent? | ivanbuz | FLUENT | 0 | November 1, 2009 16:36 |
Reynolds Stress model in CFX vs Fluent | Tim | CFX | 1 | October 7, 2009 06:19 |
Fluent 6.4 courant number | Aris Nikolopoulos | FLUENT | 0 | May 6, 2008 08:52 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
