kd
Rep Power: 15 ![]() |
hi,
i am trying to model simple problem of hydrogen dispersion. something like the model of methane and air model that exist in the tutorial guide of fluent. one inlet of air with slow velocity and small inlet of hydrogen with laminer velocity. the model is cyliner that open in the other side with outflow. i use traniset and laminer finite rate. in fluent user guide that is a sentence that say: "If you introduce fuel to an oxidant, spontaneous ignition does not occur unless the temperature of the mixture exceeds the activation energy threshold required to maintain combustion" when i choose the temp of the inlet gas 300k there is ignition but it's not suppose to happen. spontaneous ignition suppose to happen in at least 500 k of hydrogen! ![]() i hope someone can help thank very much!!! |
kd
it's very important to me! i hope someone can give me a answer
plz |
Rep Power: 0 ![]() |
Hi Friend
Try to initialize with 500k or 600k of inlet gas. |
kd
thank u! but this exactly the problem! when I initializeD the problem with 500 or 600 kelvin there is ignition!
autoignition of hydrogen suppose to be at ~830k at 1 bar ! until that temperture we need ignition sourch! someone know what the problem??? ![]() |
Nikolopoulos Aristeidis
Your problem is that your reaction rate is not zero for 300K. Where do you find the constants for activation energy and pre-exponential factor?
Moreover which is the order of the reaction with respect to oxygen? |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 04:16 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
Compared MRFSimpleFoam and Fluent in a centrifugal pump! | renyun0511 | OpenFOAM Running, Solving & CFD | 8 | July 6, 2010 06:24 |
Fluent 12.0 is worst then Fluent 6.2 | herntan | FLUENT | 5 | December 14, 2009 02:57 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
