Diesel Unsteady Flamelet Error
Old   February 12, 2011, 12:31
Default Diesel Unsteady Flamelet Error
jabulani is on a distinguished road
Hi All,
I'm attempting to use Diesel Unsteady Flamelet for Diesel engine combustion case with CHEMKIN reaction mechanism imports. There is however an error message (shown below) when I attempt to initialise the case. Much appreciated if anyone can explain or help out.
Error Object: #f
Tox = 313 K, Tfu = 313 K, <X> = 0 /s, <p> = 101325 Pa
Initializing unsteady flamelet
Failed to calculate stochiometric mixture fraction: Assume fsto=0.5
Done.
Generating PDF lookup table
Type of the PDF Table: Nonadiabatic Table with Single Flamelet Model (Two Streams)
Calculating table .....
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error:
Error Object: #f
jabulani is offline   Reply With Quote
Old   June 26, 2013, 16:45
ALj89
AbolfazlJalalabadi is on a distinguished road
Originally Posted by jabulani View Post
Hi All,
Error Object: #f
Done.
Error:
Error:
Error Object: #f
I have this exact problem, I'd be glad to know if you got this over with somehow, thanks
AbolfazlJalalabadi is offline   Reply With Quote
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
Problems of Duns Codes! Martin J Main CFD Forum 8 August 14, 2003 23:19
