Difference b/W vol. avg. velocity and superficial velocity
Old   March 4, 2011, 19:25
Default Difference b/W vol. avg. velocity and superficial velocity
Mohammad Waseem Tahir
mwtengr is on a distinguished road
hi all
i have a little confusion, i will be very thankful if someone can clerify it:
if i use the superficial velocity (vol. flow rate/X-Area) then permeability can be given using the darcy's law as follows:
K = mu*v_s/delta p; where v_s is superficial velocity, and delta p is the gradient of the pressure (pressure drop per unit length).
In fluent i can get the volume averaged velocity under Reports-> volume integrals->, my question is that is this vol. averaged velocity is the same as the superficial velocity, and can i use it to calculate the K above.
thanks
mwtengr is offline   Reply With Quote
Old   March 5, 2011, 08:20
Amir's Avatar
Amir
Amir is on a distinguished road
I don't think so. if you compare superficial and physical velocities, you can understand their differences.
superficial kind is a type of velocity that doesn't consider solidity for velocity increment in porous media and can change through your media but volume average type is totally different!
in other words, volume average of superficial velocity is volume average one. but for calculating average permeability you can use above procedure.
Amir is offline   Reply With Quote
superficial velocity Taskin FLUENT 9 August 16, 2017 14:22
Should I be using True or Superficial Velocity for Porous Domain? siw CFX 2 November 17, 2010 07:52
Superficial Fluid Velocity. beezee99 FLUENT 2 October 24, 2010 19:33
superficial velocity discovolante Main CFD Forum 0 April 28, 2009 06:52
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
