Heat transfer through 2 solid layers
Like Tree1Likes
  • 1 Post By Kwiaci
Old   March 12, 2011, 12:12
Default Heat transfer through 2 solid layers
Robert
Kwiaci is on a distinguished road
Hello Everyone!
I'm new here and it's my first post. I'm currently performing some heat transfer analyses in FLUENT.
I want to obtain a temperature distribution in function of time in a solid body containing 2 layers: titanium and aluminum. It is an unsteady 2D analysis. The problem is that internal wall between these solids don't transfer heat. Do you know why or what boundary condition should be used there?
Second question: does anyone know how to model in Fluent a thermal contact resistance ?
In attachment there is a plot of current result.
Thanks,
Kwiaci
Kwiaci is offline   Reply With Quote
Old   March 12, 2011, 20:32
xrs333
xrs333 is on a distinguished road
"coupled" type should be used.
xrs333 is offline   Reply With Quote
Old   March 13, 2011, 02:38
Robert
Thanks,
Yes I did "coupled" there by doing two interfaces there. Now it works great.
Old   March 13, 2011, 06:27
etienne
hittie is on a distinguished road
hi,
where did you find the coupled option? because i have also a problem for the heat transfer.
thanks
hittie is offline   Reply With Quote
Old   March 13, 2011, 13:42
Robert
In Gambit you make two interfaces in place where two solid are in contact. Then in Fluent you use "Grid Interface" option to couple them. Next Fluent creates a new item - shadow which is interface between these two solids. In thermal options of this boundary condition there is coupled option. That's all.
nenazarian likes this.
Old   March 13, 2011, 17:07
etienne
thanks a lot
Old   March 14, 2011, 06:28
sushil goswami
fufilnikku is on a distinguished road
Hi all
I am trying to simulate a concentric tube heat-exchanger in 2D.
The heat-exchanger data is as given below:
inlet tube internal diameter = 54mm
pipe thickness = 3mm (aluminium)
Outer tube diameter = 159mm
Heat-exchanger height = 1000mm
i have meshed the whole geometry using mapped meshing in gambit with quad mesh.
I have modelled two mesh models. one with 5 zones: water-aluminium-gas-aluminium-water. Second with 3 zones: water-gas-water with walls separating the zones from each other instead of solid zones (aluminium).
inlet velocity for gas = 0.5m/s with 723 K. I%= 5% & hydraulic diameter = 0.054m
inlet velocity for water on left zone = 0.2 m/s with 323 K. I%=5% and hydraulic diameter = 0.052m
the outer tube walls are defined as adiabatic Boundary condition.
I am unable to decide the 'Boundary condition' for the walls separating water from aluminium and aluminium from gas to allow heat transfer from gas to aluminium and from aluminium to water.
In 2nd geometry with 3 zones only, how should i define the 'Boundary condition' for the walls separating water from gas to allow heat-trasnfer between gas and water. in this geometry, i am defining wall thickness as 3 mm to account for aluminium.
I can email the .cas & .msh files to anyone who could help. I would highly appreciate your help.
Thanks in advance.
Sushil
fufilnikku is offline   Reply With Quote
Old   March 14, 2011, 09:17
Robert
Did you created "interface" boundary condition between aluminium and gas? It should help. It is very convenient way to do this. When you create interface don't merge lines in Gambit so you will get two lines coincident in one location. I hope it'll help a bit.
Old   March 14, 2011, 12:39
sushil goswami
Thanks for your reply. I am kinda new to GAMBIT but i will give it a try. I would try to create interface BC for the the 2D model.
heat transfer, layers, unsteady
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
No Heat Transfer between two solid domains Mike ZH CFX 7 July 26, 2008 16:50
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
