Natural convection in a closed domain STILL NEEDING help!
Old   March 28, 2011, 07:44
Default Natural convection in a closed domain STILL NEEDING help!
Gregory
Yr0gErG is on a distinguished road
Hi FLUENT users, I am trying to model natural convection in a closed car cabin with radiation. Below is the summary of my solution. But the temperature and velocity distributions do not seem to make sense, and the mass flow rate between two arbitrary planes steadily increases with more iterations. Please give me your valuable advise, please!
I would be glad to answer any questions.
FLUENT
Version: 3d, dp, pbns, rngke (3d, double precision, pressure-based, RNG k-epsilon)
Release: 6.3.26
Title:
Models
Model Settings
Space 3D
Time Steady
Viscous RNG k-epsilon turbulence model
Wall Treatment Standard Wall Functions
RNG Differential Viscosity Model Disabled
RNG Swirl Dominated Flow Option Disabled
Heat Transfer Enabled
Solidification and Melting Disabled
Radiation None
Species Transport Disabled
Coupled Dispersed Phase Disabled
Pollutants Disabled
Pollutants Disabled
Soot Disabled
Boundary Conditions
Zones
name id type
air 2 fluid
outlet 3 wall
bottomhalf 4 wall
tophalf 5 wall
rearwindscreen 6 wall
frontwindscreen 7 wall
default-interior 9 interior
Boundary Conditions
air
Condition Value
Material Name air
Specify source terms? no
Source Terms ()
Specify fixed values? no
Local Coordinate System for Fixed Velocities no
Fixed Values ()
Motion Type 0
X-Velocity Of Zone (m/s) 0
Y-Velocity Of Zone (m/s) 0
Z-Velocity Of Zone (m/s) 0
Rotation speed (rad/s) 0
X-Origin of Rotation-Axis (m) 0
Y-Origin of Rotation-Axis (m) 0
Z-Origin of Rotation-Axis (m) 0
X-Component of Rotation-Axis 0
Y-Component of Rotation-Axis 0
Z-Component of Rotation-Axis 1
Deactivated Thread no
Laminar zone? no
Set Turbulent Viscosity to zero within laminar zone? yes
Porous zone? no
Conical porous zone? no
X-Component of Direction-1 Vector 1
Y-Component of Direction-1 Vector 0
Z-Component of Direction-1 Vector 0
X-Component of Direction-2 Vector 0
Y-Component of Direction-2 Vector 1
Z-Component of Direction-2 Vector 0
X-Component of Cone Axis Vector 1
Y-Component of Cone Axis Vector 0
Z-Component of Cone Axis Vector 0
X-Coordinate of Point on Cone Axis (m) 1
Y-Coordinate of Point on Cone Axis (m) 0
Z-Coordinate of Point on Cone Axis (m) 0
Half Angle of Cone Relative to its Axis (deg) 0
Relative Velocity Resistance Formulation? yes
Direction-1 Viscous Resistance (1/m2) 0
Direction-2 Viscous Resistance (1/m2) 0
Direction-3 Viscous Resistance (1/m2) 0
Choose alternative formulation for inertial resistance? no
Direction-1 Inertial Resistance (1/m) 0
Direction-2 Inertial Resistance (1/m) 0
Direction-3 Inertial Resistance (1/m) 0
C0 Coefficient for Power-Law 0
C1 Coefficient for Power-Law 0
Porosity 1
Solid Material Name aluminum
outlet
Condition Value
Wall Thickness (m) 0
Heat Generation Rate (w/m3) 0
Thermal BC Type 1
Temperature (k) 300
Heat Flux (w/m2) 0
Convective Heat Transfer Coefficient (w/m2-k) 20
Free Stream Temperature (k) 300
Enable shell conduction? no
Wall Motion 0
Shear Boundary Condition 0
Define wall motion relative to adjacent cell zone? yes
Apply a rotational velocity to this wall? no
Velocity Magnitude (m/s) 0
X-Component of Wall Translation 1
Y-Component of Wall Translation 0
Z-Component of Wall Translation 0
Define wall velocity components? no
X-Component of Wall Translation (m/s) 0
Y-Component of Wall Translation (m/s) 0
Z-Component of Wall Translation (m/s) 0
External Emissivity 1
External Radiation Temperature (k) 300
Wall Roughness Height (m) 0
Wall Roughness Constant 0.5
Rotation Speed (rad/s) 0
X-Position of Rotation-Axis Origin (m) 0
Y-Position of Rotation-Axis Origin (m) 0
Z-Position of Rotation-Axis Origin (m) 0
X-Component of Rotation-Axis Direction 0
Y-Component of Rotation-Axis Direction 0
Z-Component of Rotation-Axis Direction 1
X-component of shear stress (pascal) 0
Y-component of shear stress (pascal) 0
Z-component of shear stress (pascal) 0
Surface tension gradient (n/m-k) 0
Specularity Coefficient 0
bottomhalf
Condition Value
Thermal BC Type 2
Temperature (k) 300
Heat Flux (w/m2) 0
Wall Motion 0
tophalf
Condition Value
Thermal BC Type 2
Temperature (k) 300
Heat Flux (w/m2) 0
Wall Motion 0
rearwindscreen
Condition Value
Thermal BC Type 4
Temperature (k) 300
Heat Flux (w/m2) 0
Convective Heat Transfer Coefficient (w/m2-k) 0
Wall Motion 0
External Radiation Temperature (k) 340
Yr0gErG is offline   Reply With Quote
Gregory
frontwindscreen
Condition Value
Thermal BC Type 4
Temperature (k) 300
Heat Flux (w/m2) 0
Wall Motion 0
default-interior
Condition Value
Solver Controls
Equations
Equation Solved
Flow yes
Turbulence yes
Energy yes
Numerics
Numeric Enabled
Absolute Velocity Formulation yes
Relaxation
Variable Relaxation Factor
Pressure 0.3
Density 1
Body Forces 1
Momentum 0.5
Turbulent Kinetic Energy 0.8
Turbulent Dissipation Rate 0.8
Turbulent Viscosity 1
Energy 0.8
Linear Solver
Solver Termination Residual Reduction
Variable Type Criterion Tolerance
Pressure V-Cycle 0.1
X-Momentum Flexible 0.1 0.7
Y-Momentum Flexible 0.1 0.7
Z-Momentum Flexible 0.1 0.7
Turbulent Kinetic Energy Flexible 0.1 0.7
Turbulent Dissipation Rate Flexible 0.1 0.7
Pressure-Velocity Coupling
Parameter Value
Type SIMPLE
Discretization Scheme
Variable Scheme
Pressure PRESTO!
Momentum First Order Upwind
Turbulent Kinetic Energy First Order Upwind
Turbulent Dissipation Rate First Order Upwind
Solution Limits
Quantity Limit
Minimum Absolute Pressure 1
Maximum Absolute Pressure 5e+10
Minimum Temperature 1
Maximum Temperature 5000
Minimum Turb. Kinetic Energy 1e-14
Minimum Turb. Dissipation Rate 1e-20
Maximum Turb. Viscosity Ratio 100000
Material Properties
Material: air (fluid)
Property Units Method Value(s)
Density kg/m3 incompressible-ideal-gas #f
Cp (Specific Heat) j/kg-k constant 1006.43
Thermal Conductivity w/m-k constant 0.0242
Viscosity kg/m-s constant 1.7894001e-05
Molecular Weight kg/kgmol constant 28.966
L-J Characteristic Length angstrom constant 3.711
L-J Energy Parameter k constant 78.6
Thermal Expansion Coefficient 1/k constant 0
Degrees of Freedom constant 0
Speed of Sound m/s none #f
Material: aluminum (solid)
Density kg/m3 constant 2719
Cp (Specific Heat) j/kg-k constant 871
Thermal Conductivity w/m-k constant 202.4
FLUENT
Release: 6.3.26
Title:
Models
Model Settings
Space 3D
Time Steady
Radiation None
Pollutants Disabled
Pollutants Disabled
Soot Disabled
Boundary Conditions
Zones
name id type
air 2 fluid
outlet 3 wall
bottomhalf 4 wall
tophalf 5 wall
Old   February 6, 2012, 12:23
Default modeling ventilation of a room (only cosidering buoyancy forces due to temp grad)
arun b
arunbollavarapu is on a distinguished road
hi , iam modeling ventilation of a room , having two windows located on oposite walls, room is square of 3.5m , temp of air in room is 303k , ambient temp is 293k , iam considering 2 domains one is for room another is for atmosphere, boundary conditions taken are interior for windows , pressure inlet for atmospher boundaries , remaning are walls, are these B.C's are sufficient for modeling natural convection taking place because of buoyancy forces ? shall i consider boussinesq approximation ? shall i specify operating density in operating conditions? what should be the density in material panel ? constant,incompressible ideal gas , piecewiseliner,piecewise polynomial,which one shall i take? fluent user guide specified that bossinesq approximation should not be used for my case , if any have idea about specifying density as function of temp . pleeeeeeeeeese help me
arunbollavarapu is offline   Reply With Quote
Old   June 12, 2013, 02:12
Yash Ganatra
yashganatra is on a distinguished road
Refer literature. Boussinesq is valid for a max temp difference of 20 deg celsius.
yashganatra is offline   Reply With Quote
Old   December 2, 2019, 00:04
Unhappy modeling convection and buoyancy in fluent
mai Minh
maiminh0110 is on a distinguished road
hello everyone, I am in trouble with convection an buoyancy of water depend on gradient of temperature, however, my model is not closure domain. for detail, my model include a hollow cylind, it's heating up itself and it will be dropped down under-water (enclosure in large volume with inlet 0m/s and outlet (operating pressure) ) (under the sea in real life). So when cylind's temperature was increasing, the water inside cylind was heated and descreased in pressure, the water will be moved up by different of pressure.
I want to simulation the descreasing temperature capacity of water when cylind be heated, but i wasn't found anyway to modeling this physical action, i thought that i was wrong in the set up geometry or boundary conditions. So i very appriciate of your help
maiminh0110 is offline   Reply With Quote
Natural convection in a closed domain help! Yr0gErG FLUENT 3 March 23, 2011 05:27
how to estimage air speed with natural convection? Pei-Ying Hsieh Main CFD Forum 2 May 1, 2008 15:29
Natural Convection in closed hydrothermal system Scott FLUENT 0 March 24, 2008 19:46
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 04:58
natural convection at high Rayleigh mauricio FLUENT 2 February 23, 2005 19:43
